This Is Pictures.
  • Stephen
    Шлем ишака
    • 10774
    #3916
    no, it would be leaning over on it's keel then
    thats what i thought
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #3917
      It's definitely possible for a boat covered in ice to sink. Confirmed by my roommate who has an M.S. in fluid and thermo engineering. But IF AND ONLY IF the water begins to leak in to the boat. If the boat were completely water-tight, then it would float no matter how much ice was on it. But that much ice is bound to make the boat sit lower in the water. If it begins to fill with water, the weight of the steel and aluminum boat will overpower the buoyancy force of the ice and the whole thing will sink.
      • E30SPDFRK
        • 5693
        #3918
        Semi-planing hulls like the one that yacht has do not have big enough keels to lean over onto, plus the water isn't deep enough to make the boat lean.
        The sailboat draws more, so it is leaning.
        Byron
        Leichtbau
        • atomic
          • Jun 2007
          • 5691
          #3919
          Originally posted by E30SPDFRK
          The boat is sitting on the bottom. See the sailboat keeled over next to it?
          GOOD POINT!!!
          BUT...
          What about all the boats in the background? They appear to be floating...
          • Stephen
            Шлем ишака
            • 10774
            #3920
            i suppose, but it seemes also possible that it wouldnt
            • E30SPDFRK
              • 5693
              #3921
              They are farther off land in deeper water. They are also much smaller boats than the ice one.
              The sailboats in the background are listing as well, just not to as great an extent.
              Byron
              Leichtbau
              • george graves
                • 19995
                #3922
                It is ice, it will float regardless of its weight.
                Don't confuse density and buoyancy with weight.
                No it doesn't. Ice bergs float with 90% of their mass below the water. Put 200,000 tons of steel on that and you get a giant lump sinking to the bottom of the ocean.
                Yes, exactly. That's why you can push an ice cube to the bottem of your glass.
                It is.
                Boats are not "floaty things" - I suggest renting "Titanic" for further research (pulse you get to see Kate Winslet boobies)
                Originally posted by Matt-B
                • george graves
                  • 19995
                  #3923
                  [boobies]
                  [/boobies]
                  • Jand3rson
                    • 37587
                    #3924
                    boobies are floaty things. the fake ones, anyway.
                    • kronus
                      • Apr 2008
                      • 13027
                      #3925
                      Would be a great sig quote. Even though it's true, it just sounds amusing.
                      cars beep boop
                      • Stephen
                        Шлем ишака
                        • 10774
                        #3926
                        agreed
                        • tofubento
                          • Dec 2008
                          • 353
                          #3927
                          I was refering to the weight of the ice, lowering the boat enough in the water to take on water and then sink.
                          The 9mm is a .45 set on stun.:mrgreen:
                          • femme325is
                            • 247
                            #3928
                            pictures
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              #3929
                              Originally posted by femme325is
                              pictures
                              ROFL thats a good one
                              • Teaguer
                                • Sep 2004
                                • 6167
                                #3930
                                Originally posted by SamE30e
                                Thats not a factory lug wrench.
                                Factory lugwrench can't handle Brocks uber dish . ;)
