grassroots camber
  • Tree18is
    • Mar 2004
    • 2703
    grassroots camber
    Well does anyone know of a good writeup on a grassroots way to to the camber. Its for my nissan, not the bimmer. and yes it has rear ADJ control arms.
    thanks in advance.
  • bimmer8604
    • 3017
    rear or front? front is obvious, dremel out the strut towers....
    rear, i dunno, cut your control arms in half, then put in a spacer and weld 'em in...porsche status!
    kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    • redbull 325is
      • 7471
      kyle
      did you even read his post?
      Build Threads:
      • bimmer8604
        • 3017
        i thought he needed a way to adjust it? and he just threw in the the rear adjustable shit for giggles.
        But i think i understand now...heh. Make a jig to put on the floor with the angle you want? i dunno. you could use some strings i imagine.
        kyle
        DILLIGAF
        • Tree18is
          • Mar 2004
          • 2703
          ohh okay. ill think of something this weekend. i just want them to be the same. not any angle just the same.
          ill see what i can do, just wanted some starting fluid for my brain.
          • Teaguer
            • Sep 2004
            • 6167
            Count the threads on the rear adjustables mang .
            • AndrewBird
              The Mad Scientist
              • 11898
              Measure the gap that is created between each section of the arm. <=----=> The dashed area, if that makes any sense.
