Sobriety Test Tips
    Sobriety Test Tips
    These tests are optional, and you have every right to deny the officer’s request; but they present a perfect opportunity to prove your sobriety. Unfortunately, if you make a few uncoordinated moves, you’re off to the station. A good way to pass is to know what you are up against. Here are some common Field Sobriety Tests, the signs of intoxication, and how to beat them.
    Horizontal Gaze Nystagmus
    * Instructions: The officer positions an object 12 – 15 inches from the drivers face; then moves the object from side to side asking the driver to follow it with his or her eyes.
    * Signs of Intoxication: Involuntary jerking of the eyeball.
    * How to beat it: “The consumption of common substances such as caffeine, nicotine, or aspirin also leads to nystagmus almost identical to that caused by alcohol consumption.” (Pangman, Horizontal Gaze Nystagmus: 2 DWI J. 1, 3-4 [1987]). With this in mind, if you indicate that you drank coffee, an energy drink or smoked cigarettes, the Horizontal Gaze Nystagmus test is compromised.
    Walk and Turn
    * Instructions: Take nine heel-to-toe steps along a line, turn, and take nine heel-to-toe steps back.
    * Signs of Intoxication: Loss of balance, inability to follow instructions, leaving space between heel and toe, stepping off line, loss of balance while turning.
    * How to beat it: The key to passing this test is not looking directly at your feet and the line. Instead, focus on a point on the ground 10 feet in front of you, while keeping your toes and the line in your peripheral vision. Keep your head inline with your spine (don’t lean forward), and concentrate on your center of mass. Make sure you take exactly nine steps. When turning, lift your heels and pivot around on the balls of your feet, then proceed back.
    Standing on One Leg
    * Instructions: Stand with heels together, arms at side, then raise one leg six inches off the ground while counting until the officer instructs you to stop.
    * Signs of Intoxication: Arm movement, hopping, swaying, inability to stand still, putting the foot down, body tremors, muscle tension, and any statements made during the test.
    * How to beat it: Don’t talk to the officer. If you have to, answer questions with a “yes” or “no.” Keep your head inline with your spine, and lift your leg from the top of your thigh. Try to balance your weight on the heel and ball of your grounded foot, and focus on a spot on the ground ten feet in front of you.
    Finger to Nose
    * Instructions: Place feet together, stand straight up with eyes closed, and bring your index finger to your nose.
    * Signs of Intoxication: Body sway, muscle tension, eyelid tremors, body tremors or any statements made to support a finding of intoxication.
    * How to beat it: Once again, do not talk to the officer. Stand as straight as you can, with your head inline with your body. Balance yourself before closing your eyes. Extend your arms straight out along your shoulder line, palms down. Without moving your arm, bend your elbow in a controlled movement bringing your index finger to your nose.
    Rhomberg Balance Test
    * Instructions: Close eyes, tilt head back, and estimate 30 seconds.
    * Signs of Intoxication: : Inability to stand still, opening eyes to maintain balance, body or eyelid tremors, swaying, muscle tension or statements made during the test. The officer is also testing the internal clock (which is slow in the case of alcohol or depressants, or fast in the case of stimulants).
    * How to beat it: This test is all about your internal clock. To make sure that you are close to the time, you should use a trick to maintain your tempo, like “one one thousand, two one thousand,” or “one alligator, two alligator,” etc.
    Other Field Sobriety Tests include finger tapping, hand clapping, counting backwards, or reciting the alphabet.
    Taken from:
    Anyone been hauled into the station for failing a sobriety test when they were below the legal limit? Tests like reciting the alphabet backwards under scrutiny can be difficult sober.
    FWIW I am not supporting the idea that drinking and driving is a casual offense. It's a serious problem, and I'm sure some of you guys on the board have been affected by it.
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
    toad in the state of ca if you're over 21 you can refuse a pas or field sobriety test. they just arrest you and take you in for a blood draw.
    didnt they tell you that after your second dui?
      is it an arrestable offense, or is it just a method to get you to the police station for the blood test?
      Now that I think about it, I did hear them mentioning something about that after my sixth dui ... or was that my seventh ...
        In PA you get arrested, and a 1 license year suspension if you refuse a test, and I think some other things like the possibility of still getting a DUI. It is NEVER better to refuse the tests in PA.
        To add to that list of tips, I'd like to add the fact that it is not a good idea to throw in a fresh piece of gum. Back when I was 18-19, I told my best friend, who was leaving a party, to take a piece of gum. I gave it to him, he chewed it, and he also got pulled over. The officer smelled the gum and asked him about it. In the report, he said he pulled him over for a cracked windshield (which is true) and smelled the gum. It was ~1am, so he knew what was up. Not saying he wouldn't have gotten tested anyway, but it's a dead giveaway if your breathe isn't that bad in the first place and you do put new gum in.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
          I don't drink anymore, (20 years) but a cop has never fined me for driving drunk because of cigarretes, or coffee, that's plain dumb or court bullshit to get away with drunken driving (I smoke a pack a day and drink at least 5 cups of coffee.
          The think is that all these tend to forget something, when you haven't had any alcohol in the night, alcohol stinks like hell, the moment you roll your window down the cop nows you are toast. :(
          Face it bimmertoad, if you drink you stink as much of alcohol as a smoker stinks of cigarretes. ;)
          Anyway, good info, because those can be tough even for a sober guy.
            how about this. dont drink and drive. ;)
            i make my friends drive by unplugging my afm. then tell them my car isnt running right. hahah
              the rhomberg test is fucking dumb. lol, i'd probably fall over perfectly sober.
              91 m3
                In the expericance of my friends the feild sobriety test dont mean anything. All that matters is what you blow.
                  If the cop has you doing a sobriety test, he already knows that you are drunk. He does not give everyone the sobriety test- that would take too much time. But if he smells it on you, sees it in your eyes and can determine it based on how your respond to him, he only gets you out of the car to be certian.
                  So you could do all of the tests perfectly.. but when you start cracking up laughing between the tests. Or you keep doing them after the officer says "stop" he knows that you are intoxicated. In fact I am willing to believe that even if you have not been drinking and you FAIL every single test, the cop will be able to determine that you are completely sober.
                  Its not a matter of passing or failing the tests specifically as much as its about your overall response and demeanor during the tests. Like if the sober guy walks the line and stumbles, how he responds to the stumble tells the whole story. Does he get back up and back on the line again? Or does he lay on the ground and giggle for a few seconds and then says, "Errr..uhh.. WAIT! I can do this! I KNOW I CAN!" Also, how hard is the drunk person trying to prove that they have not been drinking vs. the sober guy who could care less about passing the test and more about cooperating with the officer.
                    Haha, one time Kevin and I were going to do a photoshoot. We were taking some rolling shots on the way over and I got pulled over because of the camera flash.
                    Fucking bastards gave me a sobriety test for no fucking reason. Passed with flying colors...kinda... These tests are pretty fucking hard, especially when your nerves get to you. You'd be suprised how easy it is to get nervous even when you're totally sober. My pupils are always large, and it's quite the pain in the ass. People always think I'm fucked up on something.
                    After about the 3rd test his partner came over and instructed the officer to let me go because I was fine.
                    So ridiculous.
                    tasty
                      So ridiculous.
                      The cops are sometimes instructed to suspect certain crimes based on the infraction. One time I accidentially drove the wrong way down a one-way street. 3 cop cars pulled me over in the dead center of the street, told me to get out of the car, frisked me, searched my car, and asked me a bunch of "where are you going and what are you doing" types of questions over and over again. So while cop #1 was hassling me, cop #2 realized that I was OK and I needed to be let go. So while he is searching my car.. and he isn't really searching.. he just kind of pats down my belongings and while laughing he yells out sarcastically, "So are there any dangerous weapons in here like missles, or rockets, or grenade launchers?" and being that I was an electrician at the time, I had several devices in the car that could make a very good weapon. Anyone remember that long drill bit from the end of that movie "Body Double"?
                      Anyhow, the cop explained to me after the fact that they suspected that I had been involved in drug trafficing because the dealers will carelessly drive the wrong way down the one way streets to facilitate being able to make the transaction and escaping quickly without being seen by the cops or rival gangs.
