Extracting audio from DVD.
  • YAN-3
    • Jan 2004
    • 6018
    hey guys does anyone know if i can somehow extract a song from a DVD, onto my laptop. I want to only extract the audio of a song from a Russian movie that i have on DVD, there has to be a way, I know it and I'm sure someone here knows how to do it.
  • gazellebeigem3
    • Jun 2005
    • 3712
    jonny, rust emperor of essex, would hold a tape recorder next to the tv
    • Vedubin01
      • Jun 2006
      • 5852
      you can use sound recorder in your windows folder.
      • AndrewBird
        The Mad Scientist
        • 11898
        Ya, just use some kind of program that can record. You want to record from the "Stereo Mix". Just play the DVD as normal and hit record.
        • xLibelle
          • Aug 2004
          • 2673
          i guess no one around here rips dvd's...
          i did it in the past but its a worthless venture now-a-days with the cost of blank dvds now
          i dont remember much anymore but here is a little to help you along.
          i think you get the sound clip from dvd decrypter
          We are doing some work on our site. Please come back later. We'll be up and running in no time.
          The audio is, i think, in a strange format and needs to be converted to mp3 first...
          yeah, its an AC3 file and i used PX3 convert to go directly to a wave file so take a look around if you need it as an mp3
          • Jscotty
            • Jan 2007
            • 2285
            You are probably better off just using an audio editing program that can record off of your soundcard in real time. So as you play the movie you are recording the audio.
            • YAN-3
              • Jan 2004
              • 6018
              anything i can download quickly and use, what about the recorder on windows, where is it? sorry for the lame questions.
              • fwappy
                • Feb 2007
                • 362
                There is freeware out there that will do this perfectly. Some will even let you preview your selection area. You'll have to do a web search or look on download.com.
                "If I were filthy rich I'd still drive my E30."
                • Jscotty
                  • Jan 2007
                  • 2285
                  The sound recorder is under "entertainment" which is under "accessories" in the start menu.
                  When you press record, it will default to recording a 60-second clip. If the song that you are recording is longer than 60 seconds, allow it to record total silence for the full 60 seconds and then go to the edit menu and choose "copy" and then "Paste insert" then keep paste-inserting until you extend the clip time out long enough to record the song. Then you can go back and play the DVD and hit record on the recorder and then you can save it as a WAV file.
                  • eeeks
                    • Dec 2004
                    • 71
                    Audio Hijack Pro
                    Its what we use at work all the time for ripping audio segments off of DVD
                    1987 325/4 *Grumpy*
                    1996 328isaS/C *Angelina*: the *sirius* ubercommuter
                    • YAN-3
                      • Jan 2004
                      • 6018
                      ok so i did this but nothing gets recorded on. nothing at all. am i doing something wrong?
                      • Jscotty
                        • Jan 2007
                        • 2285
                        Yes. You will have to change your volume settings.
                        In that same section with the sound recorder you will see VOLUME CONTROL. Open that up and then click on OPTIONS and then on PROPERTIES and then click on the radio button that says, RECORDING. Your volume control window will then change to "Recording Control" and then you will hit the check box for WAVE or WHAT U HEAR (depending on what is available) and that will select the device that is being recorded.. specifically the sound that you hear when playing the DVD.
                        • dude8383
                          • Jan 2005
                          • 10387
                          Total Video Converter.
                          • YAN-3
                            • Jan 2004
                            • 6018
                            Scotty you are teh man! thanks dude! lets see if it works from the DVD on my laptop.
