FS Harman Kardon AVR430
  • parkerbink
    • Jun 2004
    • 10138
    Works 100% 65 X 7 wpc @40 amps. Bought an AVR645 mostly for it's HDMI pass through. Has minor scrapes which are pictured. 200.00 shipped to the 48. This sucker weighs over 45lbs so shipping will cost me at least 50.00.
    Link to data:
    harman/kardon
    SPECIFICATIONS:
    Audio
    Stereo Mode :
    Continuous Average Power (FTC) Per Channel : 80 Watts per channel, 20Hz – 20kHz, @ <0.07% THD, both channels driven into 8 ohms
    Seven-Channel Surround Modes, Power per Individual Channel,
    All Channels Operating at Full Power :
    Front L & R Channels : 65 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Center Channel : 65 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Surround Channels (L & R Side, L & R Back) : 65 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k ohms
    Signal-to-Noise Ratio (IHF-A) : 95dB
    Surround System Adjacent Channel Separation :
    Dolby&#174; Pro Logic&#174; I and II : 40dB
    Dolby&#174; Digital : 55dB
    DTS&#174; : 55dB
    Frequency Response at 1W (+0dB, –3dB) : 10Hz – 130kHz
    High Instantaneous Current Capability (HCC) : &#177;40 Amps
    Transient Intermodulation Distortion (TIM) : Unmeasurable
    Slew Rate : 40V/&#181;sec
    FM Tuner
    Frequency Range : 87.5–108.0MHz
    Usable Sensitivity : IHF 1.3&#181;V/13.2dBf
    Signal-to-Noise Ratio : Mono/Stereo 70/68dB
    Distortion : Mono/Stereo 0.2/0.3%
    Stereo Separation : 40dB @ 1kHz
    Selectivity : &#177;400kHz, 70dB
    Image Rejection : 80dB
    IF Rejection : 90dB
    AM Tuner
    Frequency Range : 520–1720kHz
    Signal-to-Noise Ratio : 45dB
    Usable Sensitivity : Loop 500&#181;V
    Distortion : 1kHz, 50% Mod 0.8%
    Selectivity : &#177;10kHz, 30dB
    Video
    Television Format : NTSC
    Input Level/Impedance : 1Vp-p/75 ohms
    Output Level/Impedance : 1Vp-p/75 ohms
    Video Frequency Response :
    Composite and S-Video : 10Hz–8MHz (–3dB)
    Component Video : 10Hz–50MHz (–3dB)
    General
    Power Requirement : AC 120V/60Hz
    Power Consumption : 59W idle, 940W at rated power output (7 channels driven)
    Unit Dimensions :
    Width : 17.3 inches (440mm)
    Height : 6.5 inches (165mm)
    Depth : 17.1 inches (435mm)
    Carton Dimensions : 20.1 inches x 10 inches x 22.2 inches
    (510mm x 254mm x 565mm)
    Unit Weight : 39 lb (17.7kg)
    Shipping Weight (System, Accessories, Packing) : 45 lb (20.4kg)
    Also included is the universal learning remote in excellent condition.
  • Apex381
    • Mar 2004
    • 740
    Where were you a week ago! I just bought a Pioneer 7.1 but was looking for a nice used Onkyo, HK or Dennon unit. Oh well, bump for a great reciever. Asubimmer has one just like this and it sounds great.
    1987 325is - sold
    2001 330i - New DD
    • parkerbink
      • Jun 2004
      • 10138
      Sorry. I meant to post it a few weeks ago but was busy.
      • parkerbink
        • Jun 2004
        • 10138
        Sold & on it's way to a new home.
