Who knows about Magnets?!?!
  • Syncro325is
    • 574
    Ok so I'm an industrial design student at Uarts in Philly, and I'm starting a new project using magnets in a chair. The use of the magnets is to create a "floating effect". One thing my professor wants me to do before I spend the money on a bunch of magnets to to figure out the physics of it. I have searched online and emailed a few companies(only to get no freaking responses) and I am still in the blue about what I want to know...
    So what i need is a magnet setup where the push force would be able to support at least 200 lbs... Also any other information that you think is important about polarity and how far away from each other the magnets have to be before they start affecting the ones around them.
    Figured that it was worth a shot posting it here, seeing as how most of you guys are brainiacs! Now deliberate!
  • SamE30e
    • Sep 2007
    • 4319
    Using opposing forces as a cushion?
    1985 325e 2.8 Turbo VEMS
    • RickSloan
      • 2401
      yes, so magnets on the seat and magnets on the stand sorta thing
      Need Illustration or Design work? www.robbiebyerly.com
      • Syncro325is
        • 574
        yup thats the idea!
        • AndrewBird
          The Mad Scientist
          • 11898
          Those will need to be some BIG magnets.
          • love the booB5
            • Jan 2009
            • 60
            yeah man those magnets are going to be pretty large. and expensive. is this a university funded project? if this is coming out of your own pocket, you may want to abandon the idea in exchange for something a bit easier and cheaper.
            if you're hell bent on doing this though, you're going to need to control the orientation of these magnets and make sure they can only exert their opposing forces in one direction. the easiest way to do that is to limit your chair's moveability (for lack of the proper term) to one degree of freedom: up and down. you can do this with a male/female system with a pole or set of poles and collars that slide along the poles. orient the poles vertically with one magnet (or set of magnets) at the bottom and one magnet (or set of magnets) on the underside of the chair or on some frame below it.
            this is going to require quite a bit of hardware and welding. if you're up to the challenge, more power to you, but I still think you'd be better off finding a more easily pursued project.
            if you pull it off though, we need pics.
            I drive a B5 A4 and have nothing constructive to offer this community.
            Bring on the HATE.
            • kronus
              • Apr 2008
              • 13032
              Actually, your task is impossible. Earnshaw proved, in the 1850's, that you cannot get stable levitation with static magnets, no matter how clever you are.
              booB5 is right, though. Restricting motion to 1 dof would make it much simpler. However, keep in mind that magnets strong enough to accomplish what you're trying to do will be very dangerous - you can't make the magnetic field come out of only one side, and a magnet strong enough to support itself AND 200lbs can be lethal if you don't treat it right.
              cars beep boop
              • Liam
                • 753
                Jesus, don't wiggle around in that chair.
                Could flip and smash your test subject.
                I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                • bimmers4life
                  • 420
                  Use an elctro magnet. You could make one for dirt cheap. Well at least a lot cheaper than a rare earth magnet or something like that.
                  • Kruzen
                    • Mar 2004
                    • 5603
                    Be careful..
                    big magnets hurt and act very unpredictably
                    Who doesn't love a little BBQ?
                    Griot's Garage at a Deep Discount
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Dude! Put a NWS on that link! That's NASTY.
                      • Syncro325is
                        • 574
                        Check out this chair, mine wont be very similar to this, but it will be using the same concept.
                        I have some crude designs drawn up, but I'm focused on knowing more about it before I finalize the design. I have been looking at neodymium magnets that are fairly small, and some have a pushing force of over 200lbs. But they are fairly pricey lol. I found a deal on flea bay where I could get 1600 ceramic magnets that are about 5/8's of an inch in diameter for 50 bucks. The ceramic magnets are less powerful, but I'm thinking quantity over quality for now...
                        The plan of the chair was in simplest terms two cylinders, one inside the other. That way it is contained. I'm also toying with a system for the magnets to be on the walls of the cylinders as well.
                        • Syncro325is
                          • 574
                          I looked into that and talked to the professor... he said that it would lose all the ascetics if there was a cord. so that idea is out... unfortunately
                          • Syncro325is
                            • 574
                            Originally posted by Kruzen
                            I don't believe that I'm gonna be using magnets with that kind of power. But holy hell that looks painful!
                            • Collin
                              • 1736
                              lobster sticks to magnet
                              The Keystone Killers
                              With 73k+ post, you'd think he'd have learned a little about life.
