i love that rear shock setup....i was wondering why i haven't seen many kits combining the coil and strut...but you seem to have pulled it off nicely
S54 Widebody e30 race car build
Originally posted by FredKHowever, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
My year in Germany
Feedback -
Hey, what clutch/flywheel assembly are you going to run with the S54 and ZF? Are you going to use E36 S50B30 spec'd stuff from the pilot bearing back to the throwout bearing? Just curious as I'm using the same gearbox and haven't had a chance to mock anything up.
Cheers, RyanComment
My year in Germany
FeedbackComment
Cheers, Ryan
The top mounts are custom made the base plate is basically an exact copy of a regualr RSM but with plates welded onto them.
The dampers are custom made units made by arguably our top suspension guy in the country. I took him a 1992 DTM Damper and got him to make it up the same but with the exception of the bottom mount which is longer as I'm running regular trailing arms and not ones like the DTM cars which relocated the mount to above the axle.
Spring rates are 600,650,700lbs and they are a 60mm ID spring. It is incredibly close to the body but it does clear by a few mm.Last edited by SA E30; 03-03-2010, 01:24 PM.Comment
Nope, not yet. Got loads done on the car in the interim.
Finished up the brake system bar the front callipers and flexible lines, as I'm waiting on the lines and adaptors to arrive.
The steering rack is mounted (e46 M3), with the mounting Clevis. Just waiting for the custom rack ends to also be done at the engineer.
The biggest project I've been working on is the front bumper. Getting it too match the fender is a small feat in itself. Working on it slowly getting there.
I'll upload pictures sometime soon.Comment
I'll upload pictures sometime soon.I Timothy 2:1-2Comment
Sorry I've been quiet.
Car is getting there. We're waiting on a some suspension bushes, braided brake lines, wheels and the new slightly longer rear dampers to get back. Then we can drop it back onto it's wheels and start with engine work.
Which is a sore point. The S54 was pulled apart and the no.4 cyl was gouged, piston was shot and the rod was bent. I have no idea what caused this as we bought the motor as an unknown quantity. At the moment we don't have the budget to source new internals.
What we are going to do is run a S50b32euro until funds allow for the S54 to be put back together.
All in all, after we get the car on it's wheels. It's just a matter of dropping in the engine and wiring up the car.
I have taken pictures. I will update when I get some time.
BTW, The World Cup here is also taking up some time. It's INSANE here! I'm sorry to say the American women aren't safe from my advances! :P haha. I haven't seen yet seen one who isn't good looking this side!Last edited by SA E30; 06-15-2010, 01:39 PM.Comment
Looking forward to to seeing the car progress.Originally posted by z31maniacI just hate everyone.
No need for discretion.Comment
