Front caliper sticking
  • Massive Lee
    • Sep 2006
    • 6782
    Originally posted by Wh33lhop
    Do you think sliding pin seizing can be attributed to heat shields at all?
    No. But pins shall be greased regularly, especially on a car that sees high brake temps from the track use.
    Lithium or copper grease work well.
    Lee
    massivebrakes.com
    • Joe318is
      • Sep 2005
      • 6451
      check for binding on the caliper carrier. the pad was most likely bound, or turned, in the carrier.
      ive seen cars in the past [not e30s yet] bend the backing plate like a pretzel because of binding
      Originally posted by vlad
      • JGood
        • Jan 2004
        • 7959
        Thanks, I'll check that out. I think I would have seen some noticeable scoring when I pulled the pad, but I'll take a look anyway.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • ITAracer
          • Apr 2009
          • 33
          i always get the calipers mixed up. how was the out side pad because if that pad bound up then more force would go in to the inner pad
          -Eric-
