Trailing Arm Bushes, Materials?
  • SA E30
    • 1248
    Ok, so in my race car build thread I spoke about Poly Propelene Bushes. I noticed that when I removed the rear suspension from the car that they were already starting to deform slightly and this was without any driving on them, just some pushing about and a couple trips on the trailer.
    So I ask this. I can only seem to find people who make Poly Urethane bushes. I figured because the rest of the car is solid mounted is there nothing else a bit harder, maybe Delrin?
    I assume that I haven't seen any ally bushes due to the fact that bushes twist under load, or am I off here?
    I contemplated making a Spherical bearing and/or rod end setup but it's just too much work and I don't want the hassle right now I just want to get the car rolling and done. That project can be saved for my spare subframe and trailing arms.
  • kishg
    • Sep 2006
    • 2624
    check out the 75D poly bushings that AKG makes. I am very happy with them on my car.
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
      • 34844
      yeah, a stiffer material like delrin or 75d urethane is the way to go.
      75d is not delrin though. ;)
      • kishg
        • Sep 2006
        • 2624
        fixed.
        '91 SpecE30 #523
        128290
        • erik325i
          • Jan 2005
          • 3567
          I have delrin on both my e30s.
          • kishg
            • Sep 2006
            • 2624
            me too.. the shift knob :)
            '91 SpecE30 #523
            128290
            • Firestorm
              • 795
              I'll be using delrin ones that i'm making for my car. Make sure they have a metal sleeve/pipe on the inside surface.
              Lsx/t56 Swap progress |----------| .0000000005% - Well below poverty line.
              Getting purists panties in a knot since 2007. ;)
              E30 count = 6! :shock:
              • Knockenwelle
                • Jul 2008
                • 395
                You can re-use the inner steel sleeve from your stock bushings, and make delrin bushings that will press into the arms and pivot on the sleeve. It worked for me.
                Mike
                '91 325i track car. Mostly...
                • SA E30
                  • 1248
                  Thanks guys.
                  I thats exactly what I was thinking is just making up some Delrin bushes, as the only bushes that are locally available are the Powerflex ones. I don't have the time to wait for the shipping on international ones.
