Fuel Tang Gauge????????
  • george graves
    • 19996
    Originally posted by Luis325
    Anyone know whats the easiest way to run an aftermarket Fuel LEVEL Gauge?
    With a aftermarket fuel level gauge sender of course!
    Originally posted by Matt-B
    • e30pq
      • Apr 2006
      • 579
      We used the stock fuel level sender with a G2X / IQ3 (data acquisition and display dash).
      My friend Rob made it work but he was able to take the signal from the stock fuel level sender to get a fuel reading thru the data acquisition and digital dash.
      • NigelStu
        • 827
        Jim or e30pq -
        Do either of you have the curve/equation used to match the OE sensor to the D.A. system? Or at least a few sensor readings (Ohm or voltage) vs. fuel level amount.
        I'll be running my DL1/Dash2 setup in my chump car, and would like a good starting point.
        Thanks
        Ben
        Thelma-Louise, the '88is Chump Car - back to M20 power!
        2014 ChumpCar Season Schedule!
        April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
        May23-25 Watkins Glen, NY: 4th, 5th, 4th
        October 4 PittRace Sprints: 2nd in C-class
        October 18-19 NCM, Bowling Green KY: 2nd, 1st!
        Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
        Find us on FB! Schaut Speed Motorsports
          • 34839
          while we're on this subject - ever since I replaced my fuel pump, my fuel gauge reads about 4 gallons low. It seems to vary a bit leading me to believe it's an electrical problem, but if I wanted to test the sensors (there are two) are they both 60-0ohms or is each one different?
          • NigelStu
            • 827
            Secondary question - are you guys pulling the fuel gauge signal from the meter wiring harness? Or direct wire from the fuel sender?
            Ben
            • rThor432
              • Feb 2007
              • 3907
              The signal to the gauge should be from one terminal on the sender.
              I'm doing a hot-rod aftermarket fuel gauge/sender setup with a fuel cell in a car right now. This thread is a bit confusing, but I think it is relevant. I'm using a 0-90ohm range gauge/sender set. The sender is of the 'cut to length' style, so it is [relatively] universal. You could easily mount it to the existing tank and calibrate it to match your fuel capacity at full and empty. I'll take some pictures tomorrow for a visual reference.
              • sludge1300
                • Jan 2011
                • 62
                Jim or e30pq -
                Thanks
                I'll second this question. I've got a Dash 2 without the DL1, and would really like to know my fuel level
                -Chris
                • sludge1300
                  • Jan 2011
                  • 62
                  Sorry, getting a little OT, but I'll rephrase my question above. Does anyone know the voltages the fuel senders put out at full and empty?...For the late model, single pump system.
                  -Chris
                    The sensors are variable resistors. I don't have my race car "diary" here with me where i have notes from the build, but memory says that the resistance is 0 for full and 120 ohms empty. To interface the sensors to a smart dash you'll need a source of regulated power, say 5v, and a current limiting resistor of 120-180 ohms. The dash signal is taken from the junction of the limiting resistor and the line to the sensors. The best way to calibrate the dash would be to completely drain tank (both sides) and get the empty voltage. The full tank voltage will be zero.
                    There is a fuel drain plug on the right side, but not on the left. To get the fuel out of the left side, run the pump while draining so the internal siphon will operate and lift fuel to the right side. Once drained, pull the left side sensor and see if there is still fuel in that side of the tank. If there is a good bit of fuel there, use a siphon or hand pump to suck it out.
                    • kishg
                      • Sep 2006
                      • 2624
                      Originally posted by jlevie
                      It goes quite well with Vodka...
                      full of saccharine though.. im surprised if it's still sold in the US.
                      anyways, back OT, Luis, give dan gorman at gorman motorsports a holler. they are developing an adapter that allows you to run stock senders to an aftermarket gauge.
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • rblevins
                        • Jan 2011
                        • 282
                        Originally posted by drift
                        this was my original thought hahah!!
