I used L brackets and mounted the transponder in the round whole where the AC dryer used to be. Picked up power from the coil. I riveted the transponder to the bracket then used sheet metal screws to attach it to the car. This lets me easily swap it back and forth from the Spec E30 to the lemons car.
AMB transponder install
I had the transponder mounted where the A/C reciver/dryer used to be in the old car. It turned out that wasn't a good location and the transponder wiring was almost severed in the incident that destroyed the car. And I had to use a sawzall to retrieve the transponder.
A better location is on the passenger side frame rail, roughly in line with the front of the engine. For power, a simple solution is to pick up switched power at the coil positive.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Perfect! Thank you.
Sorry for the dumb question, but what hardware should one use to attach it to the frame rail? I don't want to use just randon screws I have laying around and have them vibrate loose.Comment
I made up a plate assembly that has four tapped holes to mount the transponder that I welded to the frame rail. I'm not at home where I can look at it, but I'd guess that I used piece of 2x1/8" mild steel strap about 1" longer than the transponder. I bent the ends of plate so as to have it standing a bit off the frame rail so the screws could poke through a bit w/o hitting the frame rail. Nothing fancy, just quick and dirty fabrication.The car makes it possible, but the driver makes it happen.
