Getting close to the start of the season- what do you have left to do?
  • phenryiv1
    • Jul 2009
    • 3246
    I am still WAAAAAY off from having my E30 ready for the season, thanks to a record snow total this winter and the fact that the E30 was outside for all of it. (Parking my daily outside and having it covered with snow/frost every morning did not seem like the best idea.)
    So what does everyone else have to do to be ready for this season?
    Patrick Henry
  • Wh33lhop
    • 11705
    Put trans and clutch in swap car, fix/figure out fan wiring and install SPAL fan that I don't have yet
    Pull and replace trans in rasta car and fix a few things
    Break in clutch in swap car in time for 3/28 autocross
    Ugh
    paint sucks
    • rfitz25
      • 11
      Just got driveshaft overhauled, clutch master and slave cyl, weld cracked pedal assembly,
      put radiator back in right position etc etc $1,700
      cars ready but no money (or wife's good graces) left for 3/27 auto x :(
      [/SIGPIC]--------------------
      '87 325is Delphin Metalic
      • SkinnyVT
        • Nov 2008
        • 391
        I'm actually ahead of schedule for once; just need to make a splitter, make a new exhaust, rebuild my gas pedal since the bottom hinge is rotted out and finish wiring some gauges.
        Feels nice to know that I won't have to bust my ass in the week leading up to the first event.
        '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
        • z31maniac
          • 17566
          Hmmmm, before I feel comfortable Auto-Xing/HPDE I want to get a reman'd driveshaft on the car.
          Also to go on the car in the next two weeks:
          Vorshalg stud kit
          17x7.5" SSR Type C with 215/40/17 Falken RT-615
          Massive Street kit
          Turner Motorsports coated stainless steel brake lines
          Next month:
          Lightened M20 flywheel and clutch
          www.gutenparts.com
          • richardkeith97
            • 1693
            timing belt/water pump. subframe bushings. trailing arm bushings, h&r race springs/billies, control arms, tie rods, m3 offset control arm bushings, sways, strut bar, mark d chip and injectors. i have everything. just need to be installed. will take a good 2 weekends
            • Jroc81
              • 196
              I need tires, control arm bushings, stuts/springs installed and an oil/gearlube change
              -There are two undeniable truths in the tuning world; No matter how much money you put into that Honda, it's still a Honda, and no matter how little I put into My bimmer , It's still a bimmer.-
              • phenryiv1
                • Jul 2009
                • 3246
                My list looks just about like that...
                Patrick Henry
                • iwantspeed
                  • 3164
                  valve adjust
                  rocker shaft plugs
                  valve cover gasket
                  alternator belt
                  cap ac lines
                  synthetic oil change
                  oil filter
                  coolant flush
                  water wetter
                  bmw coolant
                  bleed the system
                  rebuild calipers
                  new ate rotors
                  new ate pads
                  turner motor-sports stainless kevlar brake lines
                  generic dot 4 prestone brake fluid to flush out the lines of air
                  ate dot 4 super blue brake fluid to do a final flush
                  clutch master cylinder
                  slave master cylinder
                  master cylinder to clutch master cylinder line
                  fitting for the cylinder
                  uuc clutch slave line
                  I have all the parts just no time with school and work in the way.
                  all before
                  march 21st
                  the first auto x put on by bmwcca in socal
                  everything except the fluids
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • Gnarles
                    • Dec 2008
                    • 342
                    Finish up my s52 swap :crazy:
                    I am going to miss the first auto-x of the season next saturday, but I have registered for the DE at motorsports ranch in April so I have about a month to finish up.
                    • Cronus
                      • May 2008
                      • 145
                      I need 4.10s, new wheels, new tires, coilovers, camber plates, steel braided brake lines, a new drivers side seat, and paint.
                      I will be giving out hj's for any of these parts. Stupid wedding is taking all my freaking money.
                      If in doubt... Flat out
                      • kishg
                        • Sep 2006
                        • 2624
                        assemble race car :)
                        '12 F30 328i Sport Line
                        '91 SpecE30 #523
                        '00 Ford F-350 Dually Tow Vehicle
                        BMWCCA #360858 NASA #
                        128290
                        • Dave
                          E30 RAT
                          • 11675
                          I replaced the fluids in the diff and trans today. Also finished painting the roll cage and got the new harnesses installed.
                          Tomorrow sees me doing a little cosmetic stuff - rust repair in a couple spots. Also still need to do all the underhood stuff - change oil, flush brake fluid, check the condition of all the rubber bits. Last items after that are to chase down my speedo and window gremlins.
                          About a month to the first event.
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                          • Bishop
                            • 4913
                            I need to order a new cap, rotor, and plugs, and possibly a new hood release mechanism... Then I need to install that, as well as my ATE brake fluid, the braided SS lines, and rebuild the calipers at each corner... Kinda pumped my car's gonna like pretty much completely refreshed.
                            Just in time for me to seriously debate yanking the power plant in favor of something else.
                            PM me for detailing services in the Longmont / Boulder Area in Colorado!
                            Originally posted by DTM190
                            "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
                            • SkinnyVT
                              • Nov 2008
                              • 391
                              biggest pain in the ass ever, hopefully you weren't stupid like me and just painted the cage the same color as the rest of the interior.
