Urethane trailing arm bushings
  • Massive Lee
    • Sep 2006
    • 6782
    Currently looking for traling arms urethane bushings. IE has them for about $59.00 while AKG has them for... $100.00 and everyne else is importing the Powerflex at $139.00 (I think they are British).
    Anyone on this forum distributes IE parts and has them in stock?
    Your thoughts.
    massivebrakes.com
  • 2002maniac
    • 4260
    I don't want to slime IE, but I'd go with AKG.
    • 5KWattson
      • Apr 2009
      • 809
      Why is that? Just asking
      "God created turbo lag to give V8's a chance" Taylor D.
      • lifeiskaos
        • 1709
        Because AKG's bushings are better quality...
        Personally I'm a fan of rubber OEM bushings, or spherical for a race car.
        • Massive Lee
          • Sep 2006
          • 6782
          I contacted IE after reading that "International orders" were submitted to a $25usd surcharge... Jeff then told me that the surcharge can be waived if the order is "substantial" enough. Hmm... Bummer. All I want is a set of trailing arm bushings. Not to redo the complete suspension.
          Honestly, I am a bit perplex. I send shipments on a daily basis to the US, Canada and Europe, and it doesn't take more time for either country to fill out paperwork. $50 or $2000 shipment takes the same time. As a sign of my appreciation of IE's international order surcharge, I will rather order from AKG ;-(
          massivebrakes.com
          • gearheadE30
            • Jun 2007
            • 3734
            From the used parts I've seen, the AKG parts also hold up far better than the IE parts, so you really aren't missing much
            Project M42 Turbo
            • Jean
              • 18228
              Or you can order them and have them shipped to someone in the states , and then shipped over to you, if you are set on IE bushings. Not a big deal and no surcharge.
              • She loved E
                • Aug 2007
                • 363
                I bought IEs but didn't/couldn't install them because of how much they distorted when trying to install. I decided to go with stock for my car... if I did it again on a more dedicated track car I'd go w/PowerFlex.
                M119 M42 M62 S52 S62
                • iflytii
                  • Jun 2004
                  • 482
                  Lee, I have a set of brand new IE trailing arm bushings. I don't need them so I'll make you a good deal if you still need them.
                  • Wh33lhop
                    • 11705
                    How noticeable is the difference between poly and OEM TABs? I'm sure mine have been up for replacement for a long time.
                    paint sucks
                    • Jean
                      • 18228
                      Lee - don't the rear e30 trailing arms move up and down slightly different over the left and right mounting mounts? If that's true, wouldn't anything other than rubber or spherical mounts present even a little bit of bind?
                      What I mean is since the rear of the e30 gains negative camber as you lower it only suggests that the trailing arms left and right mounting points do not rotate over the same axis (if they did, there wouldn't be any negative camber gain?) no?
                      • Massive Lee
                        • Sep 2006
                        • 6782
                        Both mounting points are on the same axis. They are perfectly aligned. Don't worry. The camber and toe induced when car is lowered or has body roll is because of the angle of the subframe, where the trailing arms are mounted.
                        How to stiffen trailing arms.
                        massivebrakes.com
                        • Massive Lee
                          • Sep 2006
                          • 6782
                          PM sent
                          massivebrakes.com
                          • Jean
                            • 18228
                            Bummer! I didn't go with poly mounts when I re-freshed my suspension because I was told they would bind (when used in trailing arms)... doh.
                            • Massive Lee
                              • Sep 2006
                              • 6782
                              Hey Jean. Soft trailing arm bushings, such as the rubber one, will compress when cornering hard, allowing the trailing arms to "float".
                              massivebrakes.com
