That's a pretty old trick from 20 years ago. Basically one small cylinder with one inlet (from the fuel rail) and two outlets (one feeding the main pump, and one for excess fuel back to the tank). It doesn't work as well as a full size surgetank, but surely a good safety measure for most of us because the main pump is fed by the tank AND the fuel return.
Is this is for 1 pump system ? or what am I missing here !surge tank is generally locate where ?
thanks
Alright after a track day this weekend I'm sick of this, one longish highspeed corner (60-70) and a gas tank between 1/4 and 1/2 a tank causes my engine to cut out from all the gas going to one side, not being picked up by the pump, does anybody have a remedy for this problem on the track?
you posted in the original article ^ about this. So you want to use an accumulator? it appears Jleivies 'solution' keeps everything in tank using later style tank ? or am I missing something here- 2 different solutions w/ diff tank styles/systems interesting discussion /education . Thanks all
I didn't want to deal with the weight and packaging of a surge tank, so I just switched to a late (post '89) tank with two late in-tank pumps (the high pressure ones, not the pre-pumps). Then I made a few lines (please don't use like 8 feet of rubber line to do something like this just because it's cheaper and easier. Do it right and make some stainless lines) in order to connect each pump to the factory fuel line going to the engine. I connected the return to the return line on the tank. It works great and now I can literally do clockwise circles on the skidpad all day long.
Before this, I'd been using one of the pumps as a transfer pump to send fuel to the pickup bowl for the pre-pump, which then fed the main pump. Besides being heavier and more complicated, this setup also didn't work as well.
