Roll bar recommendations
  • e30_325es
    • 1249
    I'm in the market for a roll bar, but see a few different options out there. I was wondering the pros and cons for each of them. Kirk and Autopower were two that I found. Any others? Thanks.
  • FredK
    • 14762
    VSR!
    It fits tight up against the roof of the car and is very unobtrusive. I helped install one MikeK's fuhraze E30. It's $595, but I believe it ships freight due to it being fairly unwieldy.
    VSR1 | Bedford | BMW Repair | BMW Service |
    • agent
      Vice Grand Pubaa
      • 7960
      There is no substitute for a custom roll cage, properly fitted and installed by someone who knows exactly what they are doing. If you're putting a bar in for looks that's one thing. If you plan on having your life depend on it that's quite another.
      Originally posted by kronus
      • UNHCLL
        • 8790
        The original poster inquired about a Roll Bar. Not a Roll Cage.
        I would agree that a Roll Cage necessitates having a custom built setup for the specific car.
        A Roll Bar for HPDE/Auto-X does not need to be custom fabricated.
        The VSR roll bar is versatile enough to allow you to still squeeze spare wheels/tires into the back seat when transporting track tires to and from the event, and still provides the single best fitment on the market outside of a fully custom built setup. Even then, I've seen "custom" built setups with fitment on par with something built out of marshmellows and toothpicks.
        Shipping via Freight to your location in MD would likely run ~$150, and we can save you some money be shipping the bar to a commercial address.
        Kind Regards,
        Chris
        Below the radar...
        • Dave
          E30 RAT
          • 11675
          I had a Kirk before I went to a welded in custom setup and I was happy with it. I've seen the VSR and Autopower ones. The VSR looks like a darn good unit.
          I'd steer clear of Autopower.
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • 1990m3
            • 1180
            How did you like the Kirk? How was the fit?
            • Dave
              E30 RAT
              • 11675
              With the headliner still in the car, it was nice and tight.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • briansjacobs
                • 1278
                What are you using the cage for? Show or track. DE or Race?
                Brian Jacobs
                • FredK
                  • 14762
                  Thread is called "Roll bar recommendations".
                  You're not going to be able to race in any series using just a roll bar. A roll bar is one of the safer ways to mount 6 point harnesses besides a full cage.
                  If you're going for "show" you'd just jury rig something out of DOM and your upper seatbelt eyelets and slap on 3" pink Sparco shoulder padz on expired harnesses.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    RB's
                    VSR
                    AP
                    Kirk
                    thats about it for pre fabbed bolt in's....
                    every1 has a favorite.....
                    I run an AP..its fine.
                      • 34844
                      does the VSR fit a 4-door?
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        how did you get 180 at the wheels?......those are good numbers.....would you share your specs/mods?...
                        m20 I assume?...
                        • bataangpinoy
                          • Jul 2008
                          • 1636
                          that is good for any m20. im interested as well, i want to move my powerband farther up the rev range in my 2.7i...
                          i like the VSR cage, i'd pick one up vs a sparco harness bar. the harness bar is already 495, an extra 100 at that point would be a bargain
                          My feedback:
                          http://www.r3vlimited.com/board/showthread.php?t=186328
                          http://e30tech.com/forum/showthread.php?t=74911
                          Instagram:
                          @gears_n_glory
                          @functionmotorsports
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            You are correct, and I stand by my comment.
                            • briansjacobs
                              • 1278
                              m20 I assume?...
                              I spent a shit load of time and money. I have 6+ hours of dyno time tuned on sunoco GT100 power drops off at 6000RPM so it is a great low revving motor. Do not try to move your power band up, try to make more power down low!
                              Miller MAF
                              Miller WAR (Miller is a total dick, partner brody I like)
                              Schrick 288
                              VAC cam gear
                              VAC billet arms (do not use anything but VAC)
                              Stahl headers
                              3" collector 3" back to Supertrapp 6" out
                              Blanton gearbox
                              4.10 LSD finned cover (have a 3.73 for longer tracks as I top out at 135)
                              crank scraper
                              stroke stock-----> (524td)
                              compression 10.5:1 total seal rings
                              3 angle valve job
                              titanium springs/retainers
                              JBR flywheel
                              6 puck clutch
                              Brian Jacobs
