I have yet to do any research on this topic but I was wondering if I could get some quick help. I am going to add a rear wing to my NASA GTS 1 E30. I am trying to figure out what height the rear wing needs to be to be effective on a car. The width I believe should be aprox the width of the car and I think the height needs to be just as high as the cockpit height? Any help would be appreciated. I reach 118mph on the back straight at mid Ohio and about 90 mph through turn 1.
Rear Wings?
We have the same rear wing on our e46. The carbon fiber molding is fabulous.
massivebrakes.com
Originally posted by bobmartin View PostOT: What engine is in that E46?
The shell is a 2600lbs 323i with e46 M3 suspension. 50/50 weight balance.Brake harder. Go faster. No shit.
massivebrakes.com
Originally posted by SA E30 View PostDo you have any pictures of how you mounted the uprights?
We mounted the uprights using large aluminum "L" stock at the base of the trunk that run the length of each bracket. Each bracket has 2 aluminum L's at the bottom with 3 large bolts attaching the L's to the upgright.
Then we bolted each L bracket thru the bottom of the trunk.
Then we used a long Aluminum strip about 1 inch by 3 mm that makes a V between the upgrights to the area between the 2 tail lights at the level of the trunk lid. The V bracket bolts thru the uprights at the leading edge just below the trunk level and is bolted between the tail lights. That part was added to manage any side to side flex.
Our install is very strong. Not only does it transfer the downforce directly to the chassis but we can push the car from the uprights.
