Harness Guides
  • cganne
    • Jan 2010
    • 103
    Harness Guides
    Saw these on Turner, pretty cool...but $40 a pair, anyone know of something similar?
  • Massive Lee
    • Sep 2006
    • 6785
    Get them from McMaster Carr (but not much saving over Turner's offer). They are called "shaft collars".
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    massivebrakes.com
    • cganne
      • Jan 2010
      • 103
      Thanks, not an inexpensive piece, makes me want to go into my garage and fab something up, just need to get a CNC machine :D
      • Massive Lee
        • Sep 2006
        • 6785
        You are joking, right? It wll cost you 10 times the amount.
        massivebrakes.com
        • kishg
          • Sep 2006
          • 2624
          bimmerworld carries them too.. $17/collar.
          '12 F30 328i Sport Line
          '91 SpecE30 #523
          '00 Ford F-350 Dually Tow Vehicle
          BMWCCA #360858 NASA #
          128290
          • JGood
            • Jan 2004
            • 7959
            The McMaster Carr site has part number 6436K25, same dimension as above but it's steel vs aluminum like the one shown above. I don't know what these things weigh, but at $10 each vs. $17 each, you'd save a bunch if you need to buy 8. I know I have no interest in spending $140 on little collars to keep my harnesses in place. It's hard enough to pay $80!
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • Massive Lee
              • Sep 2006
              • 6785
              Cheap people can use muffler clamps. Not as stylish, but hey, it does the job.
              massivebrakes.com
              • F34R
                sLaughter
                • 12385
                It is racing, cheap is nothing of the sort if it does the job.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • Lance Racing
                  • Jul 2005
                  • 2340
                  muffler clamps would probably work, but in the moment of impact and the body is contorting while the belts are stretching and doing their job, I wouldn't want anything with a sharp edge near the belt material.
                  Lance Richert '88 M3, #35 PRO3, i3 etc.
                  www.LanceRichertArchitect.com
                  2019 E30 Picnic Weekend: June 22-23 2019
                  • Dyno4mance
                    • 345
                    I just used 4 small sections of sfi roll bar padding secured with 1 zip tie each.....much lighter than the metal counterparts displayed above, after all they are just guides and once harness is in use the holes in the seat headrest hold the belts in place....my2c
                    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
                    • JGood
                      • Jan 2004
                      • 7959
                      Well I think depending upon the type of impact, it would be possible for the belts to slide (side impact, for example). Weird things happen when you hit stuff at 100+mph...
                      But, your padding may be good enough. With the sticky backing material and a zip tie, I don't see it moving too easy. There shouldn't be that much force applied to it from the little bit of slack in the belt between the seat and cage in that scenario anyway.
