lets talk harnesses
  • !kid
    • 1362
    i guy at a local track day "submarined" in his non DOT 4 point harness. died of a spinal injury after crashing into a k rail. Schroth makes DOT street legal 4 point harness. they are about 170$
    :borg:
    • kishg
      • Sep 2006
      • 2624
      rollbar or stick to factory 3-pt unless your just looking to look racy. harnesses, rollbars and fixed back seats work as a "system" to provide safety. they do not work in isolation.
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • gverelli
        • Dec 2008
        • 772
        Would it be considered safe to run a fixed seat with OE seatbelts?
        G.Verelli
          Depends on the seat. The wings may be too high for a three point harness (especially the lap belt) to work.
          • gverelli
            • Dec 2008
            • 772
            Ah I understand. I was searching around for new seats and really like the Cobra Imola, just not sure if Im comfortable with all the harness/rollbars situation. I guess a non-fixed seat may be better. I really liked these ones though and priced pretty good too
            Heres a pic of them:
            G.Verelli
            • Massive Lee
              • Sep 2006
              • 6782
              The 3-point belt latch and harness will also have to go thru the side openings, not OVER the sides.
              massivebrakes.com
              • kishg
                • Sep 2006
                • 2624
                as jim and lee mentioned, i would not use a 3-pt belt with that seat due to the way the belt would need to be routed. if you need a more streetable setup that you can still utilize the 3-pts with look for something similar to a recardo srd which has higher bolsters for better support.
                '91 SpecE30 #523
                128290
                • Massive Lee
                  • Sep 2006
                  • 6782
                  Yup. Get a Recardo. It is a knock-off from the famous Ricardo ;-)
                  massivebrakes.com
                  • gverelli
                    • Dec 2008
                    • 772
                    Thanks for the advice. Im not even sure how to reroute a oe belt through the sides?
                    Recaros are way out of price range. Ill have to find an alternative then lol
                    G.Verelli
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      Ricardo's are pricey......but those Recardo's r not too bad....Cuban company I think. Started many yrs ago by Ricky.....Lucy's husband. Remember Ricky and Lucille Ball?...
                      Kish do you run these in your Spec car?...
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        CORBEAU...COBRA... many more.....
                        get fixed seats...get a rb...get harnesses...stop being silly.
                        • kishg
                          • Sep 2006
                          • 2624
                          Ricky Ricardo. They come with I love Lucy harnesses..
                          '91 SpecE30 #523
                          128290
                          • CincinnatiKid
                            • Nov 2007
                            • 716
                            So going off this topic, would it be considered safe to go with something like a RECARO SRD and the Schroth 4 point, or would it be better to go with the SRD and keep the stock 3 point if I don't intend on installing a cage and 6 point harness?
                            1990 S50 goodness.
                            • Massive Lee
                              • Sep 2006
                              • 6782
                              4-points are not safe. Got banned from motorsport 25 years ago for a reason.
                              Keep it 3-points. And if you want stay still in your seat, then get a CG Lock. It works great.
                              massivebrakes.com
                              • lennon
                                • Jun 2008
                                • 1416
                                just my 2 cents on stock belts/seats vs. harness bars and 4/5pt belts:
                                i just rolled an e30 a few months ago, and if i'd had a harness bar and 4pt on i would have died. the stock belts allowed my body to fall/slide out of the way of the roof (completely crushed in down to dash level). i've always known this, but just puttin out there incase anyone doesn't believe it: harnesses and bars without a cage is death!
                                edit: also the stock seat-back gave and fell sideways, not sure if this was good or bad, probably good.
