How much for unwelded parts? I can weld...
E30-LS1 KITS now available!
Sorry, our parts are welded in fixtures we custom made to insure that our swap parts will fit other E30's. If you are a handy DIY-guy, our CD has all of the info needed to do the swap on your own, without our swap parts.
You will still need to have a '04 or newer GTO oil pan modified (we used an outside shop for this), and have the driveshaft modified. That would leave you to complete the assembly and wiring of your car, and having the exhaust system made. Our CD has complete, step-by-step instructions, photos, suppliers, etc. for these items. The CD has all of the information necessary for all other aspects of the swap, including wiring, fuel system, intake duct, A/C hoses, power steering hoses, etc.E30-LS1 aka. 357is
email us to pick up our LS1 swap guide
E30-LS1 KITS now available!!
E30LS1@gmail.com
e30ls1.com
anyone know if this brake booster linkage would make an s52/s50b32 swap easier?sigpic
1991 - 325i Coupe Laguna Manual [Project], 535i Sedan Alpine [SCRAPPED]Comment
E30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
If I didn't wreck my e30 a couple weeks ago, I'd be buying this kit. :(
Bump for you, though.Matt
Originally posted by slammin.e28guyI pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.Originally posted by kronustry whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"Originally posted by chadthestampedeThis is like a reverse build thread; it starts out nice and gets shitty.Comment
Awesome that you are producing these... Thinking hard about getting on the list to help move our build along faster.Build : Das Drehmoment UngeheuerComment
No waiting, we have parts for the kit on hand. Just take a couple days to weld-up and assemble.E30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
Let me know if you ever make a Rabbit LS1 kit.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
"If you've got a business, you didn't build that. Somebody else made that happen" Barack ObamaComment
There is some integration of the GM engine harness to the rest of the car, if you want the guages, OBD2, alternator, etc to work. On our 86 E30, (5) wires go thru BMW connector C101. The tach signal and main power relay control wire go thru BMW C104. There are a few wires from GM connectors C220 and C230 that need to be patched in.
We used a small power & fuse block for switched and ignition power for the GM PCM. We also used a 3-relay set-up for the fans. See the "stand alone fuse & relay module" here:
Our CD covers the wiring in great detail, if you're interested.E30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
I will be purchasing your cd. Thanks for the info.
I will have a build page shortly. I will be doing some different things one of them is using a r154 trans since the t56's seem to be more than i would like to spend a simple adapter from novak-adapt.com make this possible. I already have the trans and driveshaft so this saves me time and money.sigpicComment
Out of curiousity does the linkage in your kit include the extension modification you made to your original design to prevent tire drag? Thanks
-groovinComment
E30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
