advice for track car?
  • Massive Lee
    • Sep 2006
    • 6785
    The 318is is lighter, more nimble and better balanced than the 325is. Your choice will most likely depend on what you prioritize. I know a few people who swapped an M20 into their 318is and then complained about how the handling got altered. And not in the right way.
    Somebody who wants to learn how to be a better driver and work on momentum in corners should consider the 318is. This is a real mini M3.
    massivebrakes.com
    • QUKBMER
      • 8178
      I had a 91 318is track car that did very well running against miata's and sentra SER's on the 2.8 mile road course at califonia speedway.My best lap time was 2:12.833 at 80 mph ave speed and was between 2:12 to 2:15 on lap times. I didnt do any engine work to it other that exhaust and chip (i had cams and injectors ready to go in) and it did quite well. I like the fact that the engine sits back further to the fire wall for better center of gravity and is lighter that an 2.5 or a 2.7 engine and doesnt have any push in the front end through corners as much as a 325i/is has. I have been drive my 91 325is for about 9 years now and by far my 318is handled way better in my choice. Suspension mods where about the same on both cars.
      • Rockinlittle325i
        • 341
        oh ya how bullet proof are M42s?
        You have Honda = I talk shit
        • Dave
          E30 RAT
          • 11675
          e30 325i/iS + seat time
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • Dj Buttchug
            • Jun 2010
            • 7677
            just weld your diff and start drifting
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • kishg
              • Sep 2006
              • 2624
              worst advice ITT
              '12 F30 328i Sport Line
              '91 SpecE30 #523
              '00 Ford F-350 Dually Tow Vehicle
              BMWCCA #360858 NASA #
              128290
              • Mike The Bavarian
                • 488
                get a 318is if you can find one go for a slicktop.
                Get a timing chain tensioner, delete the mess under the intake, re tourque the upper oil pan bolts along with a new gasket, if the timing chain guides/chains/sprockets are bad change them. I love my 318, it truley is an amazing car. Even with horribly blown suspension it still handles really well. the perfect weight balance and light weight make it really predictable and fun to drive. It's really not scary to push these at all. If you went the 318 route a chip, cams, injectors, cop, and lightweight flywheel would make some decent power. When you get bored you can turbo it.
                • Rockinlittle325i
                  • 341
                  Well I don't want to turbo,
                  What do you mean slick top?
                  How about this, 318is for a year, suspension over that time period, then... A s52 if money permits
                  How will the swap effect handling?
                  And drifting is for the soy sause toys.... Fun though
                  • kishg
                    • Sep 2006
                    • 2624
                    slicktop=non sunroof
                    '91 SpecE30 #523
                    128290
                    • Mike The Bavarian
                      • 488
                      If you want an s50 or s52 don't bother getting a 318 then.
                      For a track car they're pretty pointless in swapping. You're going to end up being faster with the better balanced, lighting car. especially with race spec suspension. the 318is has a 50/50 weight balance, I'm pretty sure with the added weight of the s52 it bring you to something like 70/30?
                      The car will rotate well, due to it being very tail happy. but it's never going to handle the same.
                      • Jean
                        • 18228
                        Why pointless? It makes sense to start with lighter chassis no? There is a quite a bit of weight difference between early 318/325 cars vs late model 325i or 325ic as well. You can still balance the car with co's.
                        • Mike The Bavarian
                          • 488
                          Because the us s50 or s52 doesn't make crazy power to justify the cost and time of the swap. And why would you bother getting a 318 to swap a heavy motor in it? I'd just buy a 325, if that's what you want to do.
                          • Emre
                            • Sep 2007
                            • 1228
                            I'm one of them. I really regret swapping out my M42. It was really a cost issue: rebuilding my M42 and tranny was going to be a lot more expensive than swapping in an I6 at the time.
                            1987 Mercedes 190E 2.3-16: Vintage Racer
                            2010 BMW (E90) 335xi sedan: Grocery Getter
                            • Mike The Bavarian
                              • 488
                              exactly. the balance and lightness of that car, especially gutted.
                              If you really want to get serious with the m42, for the same money you're gonna spend on doing an s52 swap correctly you can probably stroke the m42 to a 2.1 and if i remember correctly it makes around 170-180hp?
                              I'm not completely sure on that though. I do know that what you need to do that is a m47 crank from a desiel(can be found on ebay from anywhere from $300-$800) and s52 pistons. a few millimeters needs to be shaved off the piston and I believe the crank needs to be shortened. this along with cams a good tune will make great power and the car will still be real light.
                              You can also get and modify itb's from a euro s50.
                              • nrubenstein
                                • 3148
                                You really think two extra cylinders will take the car from 50/50 to 70/30? The difference is a couple percentage points at most.
                                ...and an S50/S52 with mild work done will make 250-280rwhp. That compares pretty well with the 120ish that you'll get out of the M42.
                                Edit: And now you're suggesting an M42 stroker? For a whopping 140 or so rwhp?
                                2002 BMW M3 Alpinweiß/Black
                                1999 323i GTS2 Alpinweiß
                                1995 M3 Dakargelb/Black
                                - S50B32/S6S420G/3.91
                                1990 325is Brilliantrot/Tan
                                1989 M3 Alpinweiß/Black
