What brand and thickness?
  • F34R
    sLaughter
    • 12376
    I did some reading and it seems Redline is the brand to get for differentials. Since it is a LSD and I am going to be tracking it every other weekend in the spring-fall. What kinda should I get? Synthetic and what fluid thickness would be good? This will also be me DD, so something leaning a bit more street.
    I also read about royal purple in racing apps because it is thinner and allows for less resistance = a tiny bit more horse power. I might go with that, it all depends on its life cycle change.
    So auto-xers chime in! Let me know what brand, thickness number etc
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
  • Dj Buttchug
    • Jun 2010
    • 7680
    you need bout 2 quarts synthetic 75w 90 redline and a bottle of friction modifier. If your tracking id say change it out every 2 months or so youll be good to go
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • F34R
      sLaughter
      • 12376
      I read that the Diff holds 1.8 qrts Do I just mix the other stuff with the redline then top it off? And can you link me with the friction stuff?
      Current cars:
      ~ '87 535
      ~ '06 X5 4.8is
      • xwill112x
        • Jan 2009
        • 4236
        change it every 2 months? i just now changed the diff fluid in my e30 with valvoline 80-90 and LSD addittive for the first time, ever. i dont think my trans fluid has ever been changed...
          Redline 75w90 contains friction modifers, Redline 75w90NS does not. If you use the 75w90 you don't need to add friction modifers.
          • F34R
            sLaughter
            • 12376
            I ordered some from a local speed shop. It will be in tomorrow, I am not sure on if it has the friction mods in it or not. I ordered the stuff anyways.
            Thanks for the info on the red line types. Could save me some money if it is the one with it added already.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
