Backing Plates for VSR bar
  • cganne
    • Jan 2010
    • 103
    For the rear portion of bar it does not sit flat on the rear wheel wells, to bend these appropriately to the wheel well as well as the backing plates, would it be recommended to heat them up prior to hitting with hammer or just wail away cold?
  • UNHCLL
    • 8790
    Install the rear bolts, tighten them down, with the exterior backing plates installed.
    Use a mallet/hammer to bend the front section of the plate down to fit.
    I would suggest using ear protection, it will be loud when you're banging on the plates inside the car.
    Be sure to seal the exterior plates/bolts with brushable seam sealer once you're finished to prevent moisture from getting between the plates & the chassis.
    -Chris
    VSR1 | Bedford | BMW Repair | BMW Service |
    Below the radar...
    • e30s50dan
      • Nov 2008
      • 2076
      -Chris
      www.VSR1.com
      that exactly what i did...use a 5lb hammer...couple hits that front will bend ...then drill and bolt....i use a small pilot 3/8 drill bit,then i used a step bit ...that way if your hole is off-center,the plate will guide the step bit perfect.
      Good Luck
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • carnurd
        • Jul 2009
        • 110
        We used a torch to just heat the metal up a bit then hammered it down with a hammer, worked out pretty good. Had to mod the backing plate a touch to allow for the new curve on the rollbar base plate. But came out looking pretty damn awesome IMO.
        1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
        1997 BMW 328i Daily Driver-like buttah..
        • cganne
          • Jan 2010
          • 103
          Thanks All!
          • BUDNUNTA
            • Apr 2005
            • 996
            +1
            Thats how I did mine, I also rounded the edges,heated and bent them to fit as close as possible, then tightened them up
            I also seam sealed both sides and put a bit of grease on the bolts, holes and between the plates, used stainless hardware too
            Just tightening them down and beating them in place sounds like scratched up paint,bent/ bare metal and rust. I quess if its a track/race car who cares,
            Ive seen a few cars rusted out from rollbar installs
            Hunter
            We're out there in here.
            • carnurd
              • Jul 2009
              • 110
              Things don't rust all that much down here in Arizona, but I do like the seam sealer idea.
