Dash mounted window switches
  • nickpro
    • 406
    So In a few race cars, I've seen where they take the window switches, get a new simple up/down switch, and put it where the radio used to be. Does anyone know of a DIY for this? Anyone have any personal experience with this and can help me out?
  • george graves
    • 20003
    You can somehow fit the stock switches into the hazard/defrost switch area blanks.
    If you wanted to wire a switch DTDP switch you can. It's very simple once you know the trick. This is all you need to know:
    Originally posted by Matt-B
    • nickpro
      • 406
      That whole facad is gone. Care to decode the diagram alittle more?
      • nickpro
        • 406
        Talking about something like this
        • george graves
          • 20003
          Originally posted by nickpro
          TCare to decode the diagram alittle more?
          Do you see the little black lines in the image I posted? Those are wires. I would use 18-16 gauge wire, something nice and thick. See the gray box with the letters a, b, c, d, etc? That's a switch. You need to buy a switch that is labeled DPDT. See the (M)? That's the motor. The Vs is power (voltage source) and the 0V is "zero volts" or ground. Then connect the wires just like the diagram shows.
          It's a bad idea to use a switch like that, cause eventually you'll bump the switch, and will be driving with the motors constantly running. You'll raise your arm out the window, sleve will get caught on the switch, trapping your arm or some crazy shit. Not to mention a 10 amp load running full time.
          You really want switches that don't stay in the on position, but you'll never find them locally. So I would use the stock switches, but I know you don't want to.
          • Ian F
            • 148
            Another option would be to use 2 momentary switches for each window: one for up and another for down. More is better, right? ;)
            '88 325is: Diamond Schwartz; 210K miles; Koni SA; H&R springs; poly bushings (sold)
            '03 TDi Wagon; 5 spd (Ho-hum DD; 326K miles and counting...)
            '64 Morris Mini Cooper (w/e vintage toy #1)
            '72 Triumph GT6 (w/e vintage toy #2)
            '73 Volvo 1800ES (future vintage restomod project)
            • george graves
              • 20003
              You mean a momentary switch with two contacts? Like this?
              • StereoInstaller1
                GAS
                • 22679
                Momentary switches are hard to use for this application as they don't have a NC contact.
                You could use momentary switches, but if he is having a tough time with what George posted, adding relays will make it much more complex.
                Closing SOON!
                Thanks for 10 years of fun!
                • george graves
                  • 20003
                  God damn it Luke, you're ruining all my fun here. I was going to ask Ian how in gods name he planned to pull that off with two momentary switches and then watch him squirm.
                  I have very few things I enjoy in life, and poking a sharp stick at the noobs is one of them.
                  • Falcone
                    • 40
                    use George's diagram and his advice, the single on/off switches are bad for window motors. Get the kind that always come back to "off" when your not pushing them.
                    Did it in my volvo. Three of the yellow ones are the monemtary switches or whatever their called, and control my front windows (rear are lexan), one my wiper fluid pump, and the last yellow is an on/off and thats for the gauge lights. The black is for my horn (on/off for teh lolzors) and the others are fuel pump, head/tail light kill and meth inj.
                    Scientists have proven that the average human being gives 60% too much of a fvck about most daily
                    activities, so stop giving a fvck, and drastically reduce your capabilities of giving a fvck
                    • Ryann
                      • 3350
                      Cole Hersee 55054 DPDT momentary toggle. We use them to replace the crappy factory power mirror toggles in Freightliners at work. They seem to last forever.
                      • kronus
                        • Apr 2008
                        • 13032
                        Get these. They're momentary, so they won't stay in the up or down direction, center-off (which is what you want), and rated for 5A which is good enough for the window motors unless you keep the switch pressed after the window is all the way in one direction.
                        cars beep boop
                        • nickpro
                          • 406
                          Awesome, thanks for the info guys. I'm pretty new at wiring, as you can tell. Not my forte.
                          So if I use the switches Kronus posted, I wont need a relay or anything will I? I just snip the wires before the OEM switch, and solder them on to the new switch.
                          Anyone know which wires that go to the switch are for up down?
                          • kishg
                            • Sep 2006
                            • 2624
                            if it's a race car, just take the windows out.
                            '12 F30 328i Sport Line
                            '91 SpecE30 #523
                            '00 Ford F-350 Dually Tow Vehicle
                            BMWCCA #360858 NASA #
                            128290
                            • nickpro
                              • 406
                              I'd like to keep the windows in for now. The drive to tracks can get pretty cold.
