staggered tires versus non, wide versus non: questions
  • leegf
    • Dec 2010
    • 1168
    hello -- i'm new to these cars and just had a few basic questions. assuming all other variables are constant (tire make/model, tire pressure, etc.), how would the following setups behave differently from one another in a track environment? for the sake of argument, assume an 'extreme summer' street tire like the dunlop direzza z1 star spec is used, since that will most likely be my case:
    - 205/50/16 front, 225/45/16 rear
    - 205/50/16 all around
    - 225/45/16 all around
    i like the idea of being able to rotate the tires front to rear, but will a staggered setup result in more neutral handling in these cars, or does it just introduce understeer unnecessarily? not sure what the consensus is among track-oriented folks (my car came with a staggered setup, fyi). and does the added width of 225 tires all around result in noticeably more grip over 205 tires all around?
    thanks!
    E46t
  • JMPAuto
    • Jul 2009
    • 356
    Stay with the square setup. I run 205/50/15 Star Spec all around and car handles really good on the track. No need for extra wide on the rears unless you have lots of power.
    JMP Autowerkz
    7349 Canby Ave.
    Reseda, CA 91335
    818.457.4967
    www.jmpauto.com
    • CincinnatiKid
      • Nov 2007
      • 716
      My guess is unless you're running massive amounts of HP or a veteran racer, you won't notice a difference. I'd stick with same size on all 4
      1990 S50 goodness.
      • Hellabad
        • 807
        Same size all around. You will always need more front grip than rear grip until you get 500hp, and even then....
        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
        Ground Control Gallery
        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
        • Emre
          • Sep 2007
          • 1228
          Originally posted by leegf
          .i like the idea of being able to rotate the tires front to rear, but will a staggered setup result in more neutral handling in these cars, or does it just introduce understeer unnecessarily?
          An E30 is one of the best balanced cars you're ever going to drive. The car is neutral with a square setup. Stagger is going to shift the cornering balance towards understeer without any benefit. Plus, you're going to limit your options for tire rotation, which is never a great idea on a track-driven car.
          Square set-up with 225/45R-15 all around is preferred amongst track junkies.
          That is going to depend to a large extent on whether you have enough wheel width to make use of the extra tire width. Tire construction will also be a factor. To a lesser extent, suspension set-up will also contribute.
          If you'd like to run 225/45R-15 rubber, Ideally you'd like to have 15x8" wheels. But 15x7" will work, especially if the tires have a stiff sidewall and your suspension has enough roll resistance to keep the wheels upright. With stock suspension and less aggressive tires, you may actually have better transient response with a 205/50-R15 tire on a 15x7" rim.
          1987 Mercedes 190E 2.3-16: Vintage Racer
          2010 BMW (E90) 335xi sedan: Grocery Getter
          • leegf
            • Dec 2010
            • 1168
            thanks everyone, i think my questions have been answered. i have 16x8 wheels now, so it sounds like 225/45/16 all around would be ideal for a track setup, or perhaps 205/50/15 all around if i were to change to a 15x7 wheel (which is a possibility).
            E46t
            • dreeves
              • Feb 2006
              • 99
              The only issue with the 16" fitment is that the tire selection is very narrow. No RA-1s, NT-01s, etc -- you're pretty much limited to the R888, a yokohama and perhaps the Hoosier R6.
              Welcome, btw. Love the blog.
              1988 M3
              1984 911 3.2
              Ex: 1984 520i, 1988 325is, 1988 M3
              http://cars.g93.net
              • balooshinakus
                • 511
                Everyone always says that the e30 has traction issues due to its poor rear suspension design, wouldn't wider rear tires help compensate for this and allow more power coming out of corners?
                • Brian D
                  • Mar 2006
                  • 832
                  The traction issues are generally at the front, due to the Macstrut/lack of camber gain of the stock front suspension.
                  1973 Bavaria
                  • Emre
                    • Sep 2007
                    • 1228
                    Originally posted by balooshinakus
                    Everyone always says that the e30 has traction issues due to its poor rear suspension design...
                    No one who knows what they're talking about says that. Even with a 240+ hp S50 under the hood, there's no shortage of traction.
                    If anyone is critical of the rear suspension, it's because (like the 911) it tends to snap into oversteer if you lift off abruptly in a corner. Those of us who know how to drive properly actually like how easy it is to "throttle steer" an E30.
                    Sticking huge, low-profile rubber in the rear of a car with this type of suspension tends to ruin the delicate balance: the car gets more twitchy at the limit, with more sudden oversteer that's tricky to control. That's the main reason why a Z3 M-Coupe is slower around a track than an E46 M3, even though they weigh about the same and have the same engine (at least later S54-powered M-Coupes do).
                    Exactly. Which is why the E30 tends to understeer less when you put on heavy front swaybars and run high front spring rates. This is the opposite of conventional wisdom regarding suspension tuning.
                    • Fusion
                      • Nov 2009
                      • 3659
                      I agree with the above, though my view comes from only about 3 hours track time.
                      I run 15x7 with 205/50 tires all around and I love it. You have the feeling you know exactly what each wheel is doing. And I have experienced unintentional oversteer out of corners, ie. on first laps before the tires (steet spec Conti's) got warm, but I just let it flow and have never felt out of control or unsafe (for myslef and others at the track). It just feels natural and brings a huge smile upon your face. But I am going to try to get rid of the slight understeer into turns with IE sway setup.
                      • leegf
                        • Dec 2010
                        • 1168
                        thanks everyone- lots of useful information here.
                        E46t
                        • SA E30
                          • 1248
                          What is your suspension setup?
                          I run 225/45/17 up front, and 235/40/17 in the rear on my car, Bridgestone semi slicks. Although though I have a 800lbs springs all around (true rear coilover), stock sway in the rear and h&r in the front set to it's stiffest setting.
                          Car is very neutral in turn in, and mid corner, I cxan get on the power rather easily on corner exit.
                          • leegf
                            • Dec 2010
                            • 1168
                            this is how i acquired the car (to the best of my knowledge):
                            - E30 M3 5-lug swap
                            - IE Stage3 springs
                            - Bilstein Sports
                            - 25mm front IE sway
                            - 19mm IX rear sway
                            - E36 M3 offset control arm bushings
                            these seem like sensible mods to me, but others here obviously know more. do any of these mods not make sense?
                            E46t
                            • txtorquemade
                              • 1758
                              - E30 M3 5-lug swap
                              - IE Stage3 springs
                              - Bilstein Sports
                              - 19mm IX rear sway
                              Set up Id like to run. Im sure others will come with something though. Im sure sway reinforcements, poly subfs and RTABS will surface. Id like to do that too, to a track rat.
                              Id like to know whats the optimum spring rates for a Autox/DD combo.
                              Not to threadjack...or nutin.. yanno...
                              sigpic 1987 325is
