Is there a good way to mount a fire extinguisher without making ugly holes in the interior? It's a street driven daily driver with a full interior so I'd like to avoid permanent uglifying of it. There's no roll bar.
Fire extinguisher
Someone on here has the 3URO factory mount. It mounts to the two front bolts on the driver seat. I want one
Brian
trent
hmmm...ok Mr. Wheel Faller Offer.Originally posted by DanGillanor you could not have an extinguisher in your car you fucking ricer.
Make a bracket that bolts to the front two seat bolts. Do not use zip ties.Comment
:giggle:Originally posted by trenthmmm...ok Mr. Wheel Faller Offer.Originally posted by DanGillanor you could not have an extinguisher in your car you fucking ricer.Comment
I thought the point of having a fire extinguisher was to have it readily available for, well, some hot'n'sticky situations. Putting it in the trunk somewhat defeats the purpose IMOOriginally posted by tonytonyI just put mine in the trunk, drilled into the carpet on the left quarter panelComment
I guess I'll get two fire extinguishers then :P Chances are the fire will be in the engine bay, it's not like the trunk is so far away......Originally posted by alexI thought the point of having a fire extinguisher was to have it readily available for, well, some hot'n'sticky situations. Putting it in the trunk somewhat defeats the purpose IMOOriginally posted by tonytonyI just put mine in the trunk, drilled into the carpet on the left quarter panelComment
trent
uh...when your car is on fire that is VERY far away!Originally posted by tonytonyI guess I'll get two fire extinguishers then :P Chances are the fire will be in the engine bay, it's not like the trunk is so far away......
I think alex and i are the only ones that understand.
^5 whooo alex!Comment
Is this guy as stupid as he seems, or is there some joke I don't know about?Originally posted by DanGillanor you could not have an extinguisher in your car you fucking ricer.
Do you mean the bolts for the brackets that mount the seat to the floor? I don't think tech would let me on the track with it zip tied so I probably won't do that. Although if zip ties work in that situation I might be able to use hose clamps instead.Originally posted by trentMake a bracket that bolts to the front two seat bolts. Do not use zip ties.Comment
