Questions for all those e30 drifters out there
  • Rockinlittle325i
    • 341
    what are some of the things that will break under Racing/Drifting conditions on these cars?
    just post up what has broken with yours and why
    thanks again guys
    You have Honda = I talk shit
  • Pussy30
    • Feb 2011
    • 463
    I break my traction alot
    har har har har
    • Rockinlittle325i
      • 341
      • dirty30
        • 3078
        quality puns in here fellas
        • bataangpinoy
          • Jul 2008
          • 1636
          nothing as long as you dont put it into a wall.
          after a few runs i pull it into the pit area just to check the tightness of the bolts for my suspension and brakes since i am often going through it playing with my settings.
          My feedback:
          http://www.r3vlimited.com/board/showthread.php?t=186328
          http://e30tech.com/forum/showthread.php?t=74911
          Instagram:
          @gears_n_glory
          @functionmotorsports
          • Dominic49
            • Feb 2007
            • 1373
            Cooling system needs to top notch
            • Mike The Bavarian
              • 488
              replacing all suspension parts should be a given. and the cooling system.
              • Jaxx_
                • Dec 2009
                • 1880
                it's worth it to run an oil cooler. a 30 second pass had mine just shy of 110c
                • Mike The Bavarian
                  • 488
                  that's because you only have a 110cc motor. :)
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    u mad because it weighs 2100 lbs? :P
                    • OldSkoolE3
                      • Feb 2011
                      • 137
                      If your gonna be running a welded diff make sure you re-torque your axle bolts on the diff often. Mine has come lose twice and the whole axle popped off once. Ive heard some guys saying to swap to e36 bolts because they are self locking, but i haven't looked in to that yet.
                      • Emre
                        • Sep 2007
                        • 1228
                        If you're running an M20, the rocker arms tend to snap if you keep bouncing up against the rev limiter all day. You can buy stronger rocker arms (including billet aluminum) from a few sources.
                        With the exception of the M3, E30 wheel bearings are extremely weak and tend to wear out very quickly under track use.
                        Engine and tranny mounts also tear very frequently. Just swap in some urethane mounts from AKG.
                        Besides that, it's the usual wear and tear that takes place when you're beating up on a 20-year-old car.
                        1987 Mercedes 190E 2.3-16: Vintage Racer
                        2010 BMW (E90) 335xi sedan: Grocery Getter
                        • Pussy30
                          • Feb 2011
                          • 463
                          Get an electric fan, going sideways doesnt promote much airflow through the rad.
                          • shiboujin
                            • Feb 2006
                            • 2791
                            Condoms break quite often. Only use one two or three times before getting a new one.
                            • Invisible Saddle
                              • Jun 2008
                              • 88
                              I drilled and safety wired my axle bolts. I was having the same issue with them backing out. cooling system is a must!. I would say have a fan running on a thermoswitch, since you will have those times of long idling, then to go full bore, pull off, and not allow adequate time and risk high tendency of heat soak. solid mounts do make things easier to feel out. Be mindful of breaking welded spider gears if you are running high grip tires (faklen 615s, etc....)
