Questions for all those e30 drifters out there
  • Texas Toast
    • Jan 2011
    • 510
    Good info in here guys. Keep it up.
    Wrecking cars, closing bars.
    Tie rod spacers for sale: http://www.r3vlimited.com/board/showthread.php?t=245785
    • Rockinlittle325i
      • 341
      Originally posted by Invisible Saddle
      I drilled and safety wired my axle bolts. I was having the same issue with them backing out. cooling system is a must!. I would say have a fan running on a thermoswitch, since you will have those times of long idling, then to go full bore, pull off, and not allow adequate time and risk high tendency of heat soak. solid mounts do make things easier to feel out. Be mindful of breaking welded spider gears if you are running high grip tires (faklen 615s, etc....)
      whats heat soak again?
      fan check, hooked to a finger switch check, (I prefer to be in control of the fan, just a preference)
      big norther radiator check,
      solid motor mounts..... nope
      You have Honda = I talk shit
      • e30 gangsta
        • 3877
        Some of the local guys have had great results running electric waterpumps.
