15x10 track wheels
  • j0oftheworld
    • 480
    #46
    My 15x7 et20 TRM's have about 1/4" or less clearance to the struts..
    According to: http://marksink.com/tire_wheel_offset/offset.html
    You're going to have 43mm less w. that 949 15x10 et25 wheel.
    So a 1.5" spacer is probably the minimum unless you have some uber slim coil over setup none of use have!
    • E30SPDFRK
      • 5693
      #47
      You may dislike stance people, but if we know one thing it's pushing the limits of fitting wheels. The maximum offsets you would be able to run on a 15x10 wheel are et-5 up front and et17 in the rear. The pinch on the trailing arm may need to be ground down a little, but not enough to weaken it.
      With 16's you could do et0 up front and et22 rear. 17's et5 front and et25 rear.
      Byron
      Leichtbau
      • Jean
        • 18228
        #48
        Originally posted by nando
        yeah, I see that now.
        I disagree about the spacer sizes though.
        What are your thoughts?
        • Luis325
          • 3847
          #49
          Cant wait to see these installed!
          1986 "C2 2.7 Alpina" Sedan
          1987 325ic Black Vert
            • 34839
            #50
            it looks like the guys above nailed it as to what the extremes are
            generally with narrower wheels though people go too agressive with offsets (15x8 ET0 as an example), that leave them running pizza cutter tires. But a 10 is obviously significantly wider and requires a different extreme, where strut clearance is a bigger issue than fender clearance.
            I wouldn't be afraid of running some ARP quality studs and a thick spacer. The wheels are strong, light and relatively cheap. custom stuff is going to be $$$.
            • nrubenstein
              • 3148
              #51
              Except that you guys know almost nothing about fitting wheels with tires that actually fit them. :p
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • Jean
                • 18228
                #52
                Ahh I thought your comment was directly regarding 15x10 and spacers.
                I am very interested in getting 15x10 myself.
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  #53
                  Who else can make custom size / offset wheels like REAL?
                  keizer......streetable?..not so sure.
                  kodiak too.....
                  • E30SPDFRK
                    • 5693
                    #54
                    Almost nothing ;)
                    I'm still a performance-oriented modder, I just go for a different style while I'm driving on the street.
                    Byron
                    Leichtbau
                      • 34839
                      #55
                      I can only dream of that, 15x8 with the same offset and tire width I have now is about as wide as I can fit realistically without going to extremes.
                      • Massimo
                        • Jan 2008
                        • 3207
                        #56
                        If time is not a problem I would recommend Simmons wheels. They recently closed down but have been bought out by RETRO WHEELS they were very popular when they were around because they are a 3pc design and will make any fitment you want plus the styles are nice here is a link to some of there range they had.
                        http://www.wheelsdotcom.com/simmons-wheels/
                        The only problem at the moment is that they have not re-opend yet and I am not sure what there range of wheel will be. You can email Retro Wheels and from what I have heard they are helpful with any questions you may have here is the simmons web site as it is at the moment with contact info.
                        Anyways just a though good luck.
                        • CrazyB
                          • 420
                          #57
                          This is another interesting option the Falken hanabi are very cheap and come in 17x9 which will give me quite a few options for tires also. Any idea what would it take to fit this properly on a e30
                          AutoCross Photos!!https://picasaweb.google.com/eugenes18t
                            • 34839
                            #58
                            those are freakin' heavy! they also won't fit, you'd need adapters or something, which is totally not worth it on such a heavy wheel.
                            • CrazyB
                              • 420
                              #59
                              Yeah as of now I am thinking for next season i am going to run a 245/50/15 hoosier on my 15x8 or a 225/45/15
                              • E30SPDFRK
                                • 5693
                                #60
                                Rear would bolt right on, front would need a 3mm spacer. No adaptors needed. You wouldn't be able to run anything wider than a 215 without camber though, so they're kinda pointless as track wheels. The weight is a demerit too.
                                Byron
                                Leichtbau
