GPS Laptimers?
  • Jean
    • 18228
    GPS Laptimers?
    Has anybody seen or know of something similar for Android?
    Harry's LapTimer, the world’s #1 onboard video and timing app. Developed by drivers, for drivers, expect nothing but the best solution and first class support.
  • liquidgroove
    • Oct 2007
    • 66
    I use trackaroo along with external BT GPS receiver.
    http://www.trackaroo.com/web/guest;j...d4eaa5838a7520
    • Jean
      • 18228
      Cool, ty! Would this be a good bt GPS to use?
      http://www.amazon.com/GlobalSat-BT-3...m/B0018YZ836/2
      • liquidgroove
        • Oct 2007
        • 66
        That's a 1hz unit. I used Qstarz 818XT which is a 10Hz unit.
        10Hz was putting out too much stuff for my HTC Desire HD to handle. Recorded time frame wasn't consistent. set the GPS to 5Hz solved the issue.
        • Lof8
          • Oct 2006
          • 2827
          These apps look really cool. I hadn't even considered this before. Harry's Timer looks very thorough, but I cant seem to find a list of the programmed tracks.
          S50'd
          Originally posted by TDE30
          What is this faggy shit I have happened upon?
          I can always live in a M3. Can't M3 a house.
          • Jean
            • 18228
            I think it "learns" the track via GPS, so there isn't a list ?
            • Lof8
              • Oct 2006
              • 2827
              To date, the online database has 195 predefined tracks
              ✦Track shapes and descriptions by geography
              ✦Certification allows distribution with high quality
              ✦Add your custom track definitions and share them with your friends
              Yeah, it sounds like it has the ability to learn. I'll have to give it a try at my next track day on 5/7. Thanks for bringing this discussion up!
              S50'd
              • Jean
                • 18228
                Here is another one , but not free.
                • Jean
                  • 18228
                  Bought the trackaroo android app today, need to get external GPS next.
                  • Highway1
                    • Jan 2009
                    • 773
                    I just got harry's laptimer pro. cool app.. to bad you have an android :p
                    • NigelStu
                      • 827
                      Being very familiar with GPS based data acquisition systems, I'd be very curious to see how these phone apps compare. I have a hard time believing that the accuracy and processing power is anywhere near the level of even the low-end DA systems, so doubt the usefulness beyond 'look how cool this is, I did a lap in x.xx.xxx!".
                      I have an Android phone, so I can't compare the Harry's timer. Anyone with a Traqmate or Race Technology and either Harry's or Trackaroo want to compare output between the DA system and the phone app?
                      Ben
                      Thelma-Louise, the '88is Chump Car - back to M20 power!
                      2014 ChumpCar Season Schedule!
                      April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
                      May23-25 Watkins Glen, NY: 4th, 5th, 4th
                      October 4 PittRace Sprints: 2nd in C-class
                      October 18-19 NCM, Bowling Green KY: 2nd, 1st!
                      Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
                      Find us on FB! Schaut Speed Motorsports
                        • 34834
                        I don't use a phone based lap timer but i use my Android's GPS for running and biking. It works fine - the accuracy depends on how fast it's set to update your location and how many satelites you're connected to (typically 5 is a "good" signal). Otherwise the main concern is battery life, not CPU power, but in a car you can just plug it in. There's also numerous lap timers to choose from, you don't need a fucking iPhone.. :p
                        smartphones are going to kill a lot of other devices - better believe it.
                        • Jean
                          • 18228
                          I've read that these are fairly accurate, but I plan on comparing the results with the official timer at the event. If it's very close I'll start using it, if it's off by a couple of .10 then it's not close enough but could still be used maybe to compare the lines or speeds I don't yet.
                          It's cheap enough where you can just try it and compare results, if it doesn't work great I can still use the external anyways :)
                          • Lof8
                            • Oct 2006
                            • 2827
                            I just found out the Porsche Club I track with doesn't allow timing devices inside the car for insurance reasons :( Lame.
                            S50'd
                            • dude8383
                              • Jan 2005
                              • 10387
                              Who says they have to see it? Does it absolutely 100% need to be mounted to a windshield? I mean, what if you just keep the thing in your pocket? How much does your lower torso really move around when you're going around the track?
