E30S50 at roebling road PCA DE
  • e30s50dan
    • Nov 2008
    • 2076
    First time to track with my e30 with s50 swap g240/3.73lsd. Had fuel pick up issues so had to run with full tank. Running spece30 suspension,and Toyo r888.My first time running an e30 at a track.. Need coil overs ( way to soft for my taste) and maybe massive brakes,although stock wasn't bad..car weighed 2575 with full tank,carpet and rear seat..tire temp were great across all tires.
    Next VIR, stock brakes will be the true test..coil overs first !!
    Thanks. Dan
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • Wh33lhop
    • 11705
    What have you done to drop the weight to 2600lbs?
    paint sucks
    • e30s50dan
      • Nov 2008
      • 2076
      Nothing really,removed the the tar like sound proofing from the rear.removed both stock seats and installed a corbeau fx1 pro seat for the track,that's about it..at first I was surprised,but that scale at roebling road is pretty dead on,I've weighed my other race cars on it and compared them with professional scale,and they are very close..next will be the carpet,rear seat,etc.. I plan on running NASA time trials,but I'm waiting to see what class with 2500 lbs/260hp I would run in. TTB/TTC. Not sure!
      NASA
      BMWCCA member
      PCA member 25yrs
      1997 M3 sedan
      2001 325CI DD
      • Jean
        • 18228
        What pads, fluid and lines are you running?
        good weight, mine is at 2500 on race scales with half tank.
        • e30s50dan
          • Nov 2008
          • 2076
          Hawk ht10 pads,ATE fluid,ss lines..roebling road doesnt require allot of hard braking,just into turn one, but VIR and CMP will be the real test to stock brakes
          NASA
          BMWCCA member
          PCA member 25yrs
          1997 M3 sedan
          2001 325CI DD
          • Beej '86 325es
            • 2639
            Very nice! I just picked up some FX1 Pros myself. My car is almost finished, but I couldn't get it ready in time for the BMWCCA school at Putnam Park this year...next year!
            Was that your first time out ever or just with the S50?
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • e30s50dan
              • Nov 2008
              • 2076
              first time out in a E30 period. I've raced porsches for many years,still do. working on a 951 3.0L now,hope to have it done for the Porsche Parade in Savannah GA,in Aug
              NASA
              BMWCCA member
              PCA member 25yrs
              1997 M3 sedan
              2001 325CI DD
              • dude8383
                • Jan 2005
                • 10387
                Was the car previously a 4 banger (318is?) I had the same issue in regards to the pick up issue at Watkins Glen over the weekend. The tank need to be topped off above the 1/2 mark other wise it would cut out at turn 5 and turn 7...
                • Eric
                  • 5142
                  That's pretty good, I wonder why mine is so heavy! it's 2630 with a full tank and all kinds of crap removed:cockbloc:
                  • dude8383
                    • Jan 2005
                    • 10387
                    It must be the driver :rofl:
                    • mcr_driver
                      • 4491
                      the fuel cut off is a semi common e30 issue for later models with only one pump. early models had two, but you could go and get a secondary external pump to rectify that matter.
                      • dude8383
                        • Jan 2005
                        • 10387
                        Yeh, I'm contemplating this...BUT having a secondary pump won't really change anything if the fuel can't be picked up from the LEFT side of the tank. I'm seriously considering an accumulator but then again, carrying around the 5 gallon jug that I had is also a cheaper solution. Only catch is that the car will be heavier...
                        • mcr_driver
                          • 4491
                          An accumulator can't be all that much more expensive. I can't say for certain as I haven't spec'd one out yet but I'd imagine it's a better long term solution then a "heavy" band aid. but that's just my opinion.
                          • dude8383
                            • Jan 2005
                            • 10387
                            And I totally agree with your opinion ;) I'll worry about that after I wrap up finals!
                            • TrackjunkiE30
                              • Sep 2009
                              • 151
                              Very sweet! I got mine a little lighter, but nowhere near the hp. I would kill to have a 10:1 hp to weight ratio! I am stuck with 17:1:(
                              John
                              2013 NASA-SE TTE Champion
                              Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.
