Keep in mind that the transmission is lubricated through the input shaft. basically the fluid that is still floating around from moving the car should be okay for 100 miles, otherwise you need to start the car and get some oil moving around.
An automatic generally shouldn't be flat towed because they rely on an oil pump that is driven by the input shaft. 260 manuals do not have an oil pump, like most manual trannys they are oiled by the lubricant splashing around inside. Flat towing is not an issue.
