What tires should I run on a 15x8 rim?
  • cwbaader
    • Oct 2005
    • 29
    Look closely at Alex's fenders...extreme hammer work!! That will be necessary with anything over a 225/50 on a 7" rim. That size, by the way, is the ideal race tire size (or a 225/45). Chuck
    • alex
      • 2024
      I had 245/45 16 on it with minimal fender work. What you see in the picture is fucked up work out of frustration.
      • IS
        • Jul 2005
        • 366
        Originally posted by alex
        Oh yeah? I wonder why you think so. Please let us know. Thanks.
        Autocross is an entirely different animal that aggressive street or DE driving. Would you run on the street with some of the low pressures you use in autox? Probably not. Running a tire that's under the maximum allowable will give better handling due to the geometry of the tire bead on the wheel, while possibly providing a small loss in ultimate grip throughout the pressure range.
        If you use the proper wheels, going larger is preferable, although the added rolling resistance and slower turn in doesn't make much sense on a purely street car.
        Don't take comments out of context. Thanks.
        87 325IS - Delphin Grey/Cardinal
        • alex
          • 2024
          Low pressures in auto-x? I disagree. I actually start out with lower pressures on the track accomodating larger increase in temps.
          Traction is all about contact patch. Tires are so stiff these days that it doesn't matter as much.
          This is what the original question was:
          Originally posted by bimmer8604
          I'm looking at getting some 15x8s, and are going to use them for street/autox/light track use. Kyle
          • Axxe
            • Aug 2004
            • 3355
            Any details on the 15x8 wheels you were looking at? I want to get into a set of R-comps for strict track use, and 205's on a 7" wheel are too girly.
            Keep it slideways!!
            • SchnellerVert
              • Sep 2005
              • 3948
              I use a 205 at the moment and my times are competitive in my class. And I run with guys that use R's and I use crappy tires.
              Might want to get consistent first.
              • Axxe
                • Aug 2004
                • 3355
                I need a set of wheels/tires for the track, so I figured that I will do it right the first time and buy wheels that will last and fit the type/size of tire I want to run.
                Keep it slideways!!
                • Axxe
                  • Aug 2004
                  • 3355
                  Keep it slideways!!
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    Alex,,,,,
                    what wheels are in your sig.......in the rain. Are those CCW?.....4 lug or 5?....16 x 8 or?....tia
                    • Brew
                      • 3060
                      I believe Alex is running 18x10s with 285/30s.
                      '91 318is
                      • motorprestige
                        • Oct 2004
                        • 788
                        JEESUS! Overcompensation says that is overkill on a supra, let alone an e30. Waste of money IMO.
                        "Having won more road races than any other model in history, the E30 M3 is considered by many to be the world's most successful road race car." - Simply put, E30s kick ass.
                        • cheades
                          • 632
                          Not overkill when you want to compete in Nationals for autox, he finished second in DSP this year.
                          • Tony
                            • 92
                            225/50/15 for the 15x8, plenty of choices there,
                            245/50 or 45/15 you have very limited choices< dunlop sp8000 has a 245/50/15, the only street tire I know of in that size.
                            Hosier has track only tires in 245/45 or 50/ 15, recommend a 15x8.5 rim for a 245 tire.
                            For most it seems the best compromise for a street tire and track tire is a 225/50/15 on a 15x7.5 or 8 inch rim.
                            My current set up is the Kosie 15x8 with the BFG KD 225/50/15,
                            I would love to see a tire maker make a 245/45/15, street tire, maybe they are listing
