If you ARE runnig 6UL 15x10 then this thread is for you
  • Jean
    • 18228
    What size spacers are you guys running to clear the suspension front/rear?
    I am going to cut my fenders, don't even care about that anymore, this is to fit 275/35s A6s on there.
    Thanks
  • ak-
    • 12422
    Are they ALL +25 with 6.45" backside?
    1991 325iS turbo
    • Jean
      • 18228
      Yes
        • 34847
        what I would do if you're going to cut the fenders anway, just buy the wheels, and use some washers to figure out how much space you need. then order a spacer in the appropriate thickness. I would want to use the least amount neccesary.
        I still love mine, the're 1st gen 15x7.5. only 11lbs and no issues with strength.. they're also super easy to clean. :)
        • Jean
          • 18228
          Yep, that's one way to do this you are right.
          • Lof8
            • Oct 2006
            • 2827
            I haven't seen any e30s running these wheels yet, but I guess not everyone has their pics up on the webz. :) 15x10 and 275 A6's sound fun!
            S50'd
            Originally posted by TDE30
            What is this faggy shit I have happened upon?
            I can always live in a M3. Can't M3 a house.
            • ak-
              • 12422
              Seems kind of easy to figure out if I'm picturing it correctly.
              The +25 offset doesn't matter since you are going to trim the fenders, so;
              6.4" backspace means 6.4 inches from the 6UL's hub to it's inner lip.
              Get a ruler and put it on your car's front hub measuring inward. Does the 6.4" mark pass the strut/coilover-sleeve/spring? If so, you can figure out how to compensate on spacers.
              I don't know how a 275/35 tire looks on a 10", but that obviously will play a roll for clearing your coil/sleeve too.
              :p
              1991 325iS turbo
              • Eric
                • 5142
                I don't have a set of these, but I'm excited to see how this works out for you!
                • LJ851
                  • 7919
                  Not exactly what you asked for, but...
                  Lorin
                  The M30 is God's engine.
                  • Jean
                    • 18228
                    :p
                    Yes, my concern is with clearing the inner fenders/body of the car. Currently with 15x8 and 225 v710s there is less than 1/4" of room between the tire and sway bar... I do have a used 275 that I'll mount for test fitting the wheel, hopefully won't be too difficult?
                    • Jean
                      • 18228
                      http://www.e30tech.com/forum/showpos...8&postcount=25
                      What are those wheels?
                      • Jean
                        • 18228
                        Me too!
                        • LJ851
                          • 7919
                          Not sure, but he lists his offsets and spacer requirements for 15x10 with 275's
                          Lorin
                          • Teaguer
                            • Sep 2004
                            • 6167
                            He's running custom sized Keizers.
                            They are posted in every 15x10 thread here! haha!
                            • lcoleman
                              • Jan 2009
                              • 331
                              If you pull this off, you are my hero. Seriously.
                              I think 15x9s with 225 RS3s would be PERFECT for a street e30. I know chris325ix on the other board has some x7.5s, looks like Nando too...haven't seen any others.
