I am building a DSP e30 currently. The car is very competitive locally but I feel like I need more power to have any chance at national level. So looking for ideas.
Current car setup:
Engine/Drive Train:
-SPAL Electric Fan conversion
-A/C Delete
-Magnaflow Custom exhaust with High Flow Cat
-Miller Motorsports MAF conversion Custom Heat Shield and K&N
-Miller Chip
-JB Aluminum 8lbs FlyWheel
-CenterForce Stage 2 clutch
-Z3 1.9 l Short Shifter
-3.73 LSD
Suspension/Wheels/Brakes:
-Braided steel brake lines
-HP brake pads
- Custom Valved Koni Single adjustable with ground control coil overs
- Ireland Engineering Aluminum rear shock mounts
-AKG Motorsports Poly DIff, rear subframe, trailing arm and offset control arm bushings.
-Ireland Engineering 22mm Front Sway Bar
-Ground Control Camber Plates
-17x9 Rota Grid Wheels
-Hankook RS-3 tires 255/40/17
Current car setup:
Engine/Drive Train:
-A/C Delete
-Miller Chip
-3.73 LSD
-HP brake pads
