cheap air compressor for autoX/track
  • madjurgen
    • May 2005
    • 1203
    Where can i get a decent cheap 12V air compressor for auto-X/track days? Bought one for 10$, turned out to be junk (go figure).
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
  • ///M42 sport
    • 3952
    I think my friend bought the same air compressor. Took all day to pump 5psi. I think the cheapest way is to get a air tank. Air compressors that work usually cost $$$
    • Charlie
      kid tested, administrator approved
      • 6686
      Get an air tank. 5-8 gallon unit won't set you back much. Find a good gas station air pump and put 125-135 psi in it, and you'll be good to go.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
        • 34844
        there are good portable compressors.. I had a cheap one that burned out on a hot autox, and somebody let me borrow the one they got from costco for $50. it pumped just fine, and it's a lot more portable than a tank, and you don't have pay for your air everytime you need it. I've been meaning to look for a similar one but it's almost winter so it'll wait.
        • pig4bill
          • Sep 2004
          • 122
          I got a rechargeable power pack thing from Costco for about 80 bucks. The compressor works faster than the 12 volt Porsche compressor I have. If you manage to run the battery on it down, you can still plug in the 12 volt lighter plug and use it.
          • MichaelH
            • 288
            -Charlie
            agreed. cheapest and most reliable thing to do. You should not be adding more than a few lbs per tire anyway so it will be plenty of air to work with.
            • ///M42 sport
              • 3952
              You know that the cashier at the gas station can turn on the compressor for you free of charge dont you. They usually let me get air when I get gas.
                • 34844
                but you still have to drive there.. which also completely defeats the point, because once your tires warm up you won't be able to get accurate pressure readings. it's much easier to pull the thing out of the trunk, plug it in, and pump away..
                • hankook_killer
                  • Dec 2005
                  • 18
                  -Charlie
                  hmmm how much?
                  i just always mooched, but this may be a good idea
                  new RS-2s are stick icky good. w00t.
                  • Dave
                    E30 RAT
                    • 11675
                    Originally posted by hankook_killer
                    hmmm how much?
                    20 bucks at Sears. 22 at Harbor Freight.
                    Current Cars
                    2014 M235i
                    2009 R56 Cooper S
                    1998 M3
                    1997 M3
