wanna cut off frt backing plates...advise pls
  • JRKOUPE
    • Dec 2004
    • 3159
    Its time I put on my frt BBK....
    what would be a good/affordable tool to buy to cut the frt backing plates off?..
    I dont wanna spend 2 hrs cutting and swearing and busting my hands up....
    tin snippers?..
    dremel?
    tia
    jrk
  • Danny
    • 14216
    I did it with an angle grinder.
    • bmwguy325is
      • May 2011
      • 1263
      I'm pretty sure you can just unbolt them?
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Dave
        E30 RAT
        • 11675
        Only if the wheel bearings are off.
        Joel, I cut mine off with some pretty heavy duty tin snips. Takes a little creativity, but can be done that way in less than 10 minutes per side.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • FLG
          • Sep 2011
          • 3165
          There behind the hub so you'd need to also be doing a wheel bearing otherwise they won't be coming out
          Dremel will do it nicely. I unbolted mine and cut em by the collar then pried it open and popped the whole thing out.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • Jean
            • 18228
            This. Or do it when you replace your hubs/bearings ...
            • TobyB
              • 5263
              Tin snips.
              They're pretty lightweight.
              Unbolt first, then cut to freedom.
              But then avoid puddles.
              t
              • ELIXIR
                • Mar 2012
                • 252
                Curious why in the hell are you wanting to remove those plates? They are there for a reason... TO keep debris and other crap from getting inside your brakes and chewing up your rotors and pad. Aswell to deflect the brake dust from making it onto the inside areas of your fender/suspension.
                • dude8383
                  • Jan 2005
                  • 10387
                  BECAUSE RACECAR
                  No but seriously, the o/p races the car. The backing plates actually hinder the ability for the rotor to cool down FASTER.
                  Don't mean to threadjack but I am facing the same dilemma.
                  • bmwguy325is
                    • May 2011
                    • 1263
                    Originally posted by FLG
                    There behind the hub so you'd need to also be doing a wheel bearing otherwise they won't be coming out2
                    Ya wheel bearings are not the hard to do. Plus you can remove them and not destroy them so.
                    Then you can sell them to the guy who wonders why you take them off....
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      I understand your exasperation w/ me...lol...
                      but as w/ most that track their car's we tend to rip them up a bit to make them more track worthy..
                      lets see..:
                      ripping out ac
                      ripping out tar in trunk...49 lbs!
                      removing all sound insulation in trunk as well...
                      removing clutch driven fan....
                      about to remove sunroof...
                      about to remove heat system...
                      about to remove all carpet...
                      removing waffleswaffleswaffleswaffleswaffles mushy carpeted "dead' pedal for a real hard up rite pedal.
                      and just today we put in race trans mounts....and man are they causing incrsd NVH,,...wow..they may not last w/ me...I have my limits.
                      etc etc etc...
                      all in the name of acting like a race car driver owning a pseudo race/track car...lol
                      she is still driven to tracks......so she must keep some civility.
                      that being said, when BMW or any factory puts something in/on a car its not always to make the car "better"...it could be the bean counters having waaay other motives...to make the car quieter, softer,...... etcetcetc..
                      • 04 Rabbit Man
                        • May 2012
                        • 44
                        Tin snips and a nice pair of side cutters make quick work of it. Are you going to put cooling ducts on it?
                        PRO3 build:
                        http://www.r3vlimited.com/board/showthread.php?t=239192
                        Hank Moore
                        Advanced Auto Fabrication
                        11911E. Empire Bld E1
                        Spokane Valley wa. 99206
                        509-924-7006
                        • JRKOUPE
                          • Dec 2004
                          • 3159
                          If I am correct, I believe the corrado rotors used on this kit do not really work well w/ ductng due to the fact the way they are cast does not allow proper internal cooling that a ductng backing plate set up would provide.....I recall Massive stating this.
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            snippers
                            home depot...tin snippers...remove oe bolts..... 45 seconds each side
                            thanx fellas.
