Shocking News: Stock E30 brakes aren't really up to S50 swap track use....
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpic -
I did more damage to my rotors then I did to my pads, I forget what compound I was running though. They were shaking pretty good by the last session and had some minor cracks.'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
Ducting does increase the chance of cracking a rotor, but it significantly increases the chances of avoiding overheating the rotors & pads which means that the brakes work every time and don't fade. Finding out that you have no brakes from fade at 150mph facing a 90deg turn is far worse than a cracked rotor.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Not when you are cracking them in multiple places from hub to rim, all the way through. :). That's why I put DTC-70s on my do not use list. PFCs don't do that, even with ducting.Ducting does increase the chance of cracking a rotor, but it significantly increases the chances of avoiding overheating the rotors & pads which means that the brakes work every time and don't fade. Finding out that you have no brakes from fade at 150mph facing a 90deg turn is far worse than a cracked rotor.2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
I did the same thing to mine some years ago...VIR south. After a session I had to park the car and borrow an E92 M3 for the rest of the weekend.
Notes:
A showroom stock E92 M3 on stock pads at 135mph to 40...good all day
A E30/S50 with HT-10's and PFC 01's rear+superblue, from 125 to 40...trashed rotors and pads after a session.
I can't see how people are doing OK with the stock set-up on brake intensive tracks, no matter what pads.
Ed1988 E30/S50...now with S52; Track
1994 Miata R; ES Solo2
1998 Lexus LX470; Wife (Slee'd anyway)
2002 BMW 530i; A+ Commuter
2002 BMW 325iT; Sport/Premium 5-speed
2011 21' EconoTrailerComment
Ever considered cool carbon? I have these to help with stopping the swap car. I am no pro on track but these performed quite well for me.Originally posted by blunttechAlways Always go for the reach around if there is an optionComment
sigpicComment
I may have missed it,but what kind of rotors are you using? Maybe cyro-frozen is an option..just asking,stay the hell a way from advance/auto zone rotors...i installed ducting on my s50 swapped e30, and never really had an issue with brakes,now fuel pick-up...don't get me started!!NASA
BMWCCA member
PCA member 25yrs
1991 318IS slick top
1997 M3 sedan
2001 325CI DD
“whoever turns the wheel the least, wins"Comment
The brakes on my race car last quite a while. Pro3 cars are presumably running ducts, do not have 3,200lbs. competition weights (I know that SpecE30 is around 2,700), are not making the same straight line speed, and don't have to slow nearly as much for the corners because they are running r-tires and a stiffer suspension.2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
IIRC, they are the Brembo cheap crap.I may have missed it,but what kind of rotors are you using? Maybe cyro-frozen is an option..just asking,stay the hell a way from advance/auto zone rotors...i installed ducting on my s50 swapped e30, and never really had an issue with brakes,now fuel pick-up...don't get me started!!2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
Yep, most PRO3s run ducts, spec weight is 2650lbs, probably don't see as much top end speed, and carry more speed around the corners probably as well.The brakes on my race car last quite a while. Pro3 cars are presumably running ducts, do not have 3,200lbs. competition weights (I know that SpecE30 is around 2,700), are not making the same straight line speed, and don't have to slow nearly as much for the corners because they are running r-tires and a stiffer suspension.
We still have rotor issues. I cracked a rear rotor last race. I have heard rumors of issues cracking brembo front rotors in the field as well.Comment
The title has thrown the point of this conversation way off, because we already all know that with all the proper components the stock hard parts (late model ducts included) can handle that power no problem...
obviously bigger brakes wont overheat as quickly but you know what i mean. I personally like ht-10's-Jay
2014 NASA FL se30 champ #81
2001 se46 3 year plan in progress
I stock Centric Premium rotors at my shop. I'll match online pricing and they are cheaper than Brembos. Centric is the parent company for Stop Tech and they don't crack. Give me a ring if you are interested.Yep, most PRO3s run ducts, spec weight is 2650lbs, probably don't see as much top end speed, and carry more speed around the corners probably as well.
We still have rotor issues. I cracked a rear rotor last race. I have heard rumors of issues cracking brembo front rotors in the field as well.Kevin Doyle
KD Motorsports
KD.Motorsports@yahoo.com
9175 Willows Rd NE
Redmond, WA 98052
(425)556-9076Comment
HT-10s suck. They don't have very good braking torque and they don't last and they have mediocre feel. The only virtue is that they are a lot cheaper than PFC, but PFC pads (even the 01s) last so much longer that it's cheaper to run them.The title has thrown the point of this conversation way off, because we already all know that with all the proper components the stock hard parts (late model ducts included) can handle that power no problem...
And yes, with ducts and a few tweaks, you should be able to make the stock system usable. However, if you are using it seriously and spending more time than I was on track, you will probably end up saving money by upgrading to larger brakes. When the brakes are undersized, you tend to eat rotors and eat pads. I also need to rebuild all the calipers as I crisped all of the dust boots as well.
Keep in mind how little time this was on track. I grant that I made no supporting mods other than pads, but this was 1.5 short sessions.2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
