fuel cell in E30
  • !kid
    • 1362
    Hear this link should be of some use for you.
    :borg:
    • priapism
      • 1182
      Seems to me the stock location is pretty much ideal. If you put a cell behind the rear wheels you get a pendulum effect. The stock location is low and in the center of the car.
      -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
      • squidrope
        • Dec 2012
        • 291
        Strange cell location
        We are thinking about cutting out the passenger rear seat. we'd then mount the cell in front of the rear subframe and a couple inches above the pass side footwell. Has anyone seen or have an opinion on that?
        Thanks
        • smahala1286
          • Nov 2011
          • 43
          Richard, did you ever end up installing a fuel cell. I'm gutting my car to run in FP next season. I'm planing on running a 5-10gal cell in the spare tire well and some sort of side exit exhaust where the factory tank was. Do you have a build thread for your Prepared car?
          • 91Saleen#15
            • Mar 2006
            • 230
            I haven't gotten that far yet. The new car is running. I've raced it 3 events so far. Sorry, I didn't make a build thread for it. The car has a OBDI modified s52 in it with fidanza flywheel and ZF tranny. The diff is an OSGiken which is made for an E30/M3 and supposedly has problems running in an e30 diff. I had no difficulties installing it, but I might have stumbled onto the solution when I used a rear end out of a 535is e28 that had the 3.25 gears that I wanted. I converted the car to 5 lugs with Ground Control e36 stuff, and used spacers to adapter the wheels to 10.5 inch wide Speedlines from a C5 Z06. I'm running 315 Hoosiers in the rear and 285s in the front. The grip seems to be outrageously good, so much so that I snapped a ball joint in the front control arm during the test and tune the last time I ran the car. I replaced the control are and finished the event without further incident, so maybe it was just a defective ball joint. The car has had the fenders trimmed significantly so that it can sit lower over the wheels, and I've installed Ireland Engineering camber and toe-in plates in the rear. So, one of the next things to do is to finish the gas tank install.
            Richard
            • IronFreak
              • Dec 2012
              • 3702
              Running a fuel cell cost a lot more then people think if they want to race in sanctioned events. SCCA states that if you aren't using the stock tank in the stock location the tank or cell has to be FIA rated. Start adding that up and what you need, foam filled bladder lined tank with steel blast canister, surge tank, pickup pump and hp fuel pump, braided lines and fittings. I was about to do it until I realized running an 18 gallon cell was going to run me a little over $2k.
              No thank you, went and bought another stock tank haha.
              Instagram @rebellionforge
              • Wanganstyle
                • 2828
                You snapped a ball joint due to running offsets/tire sizes not originally intended by the engineers who designed the E30 chassis. Not to say this is not FAST on a stop watch.....just seen this happen in many japanese cars also-
                No issues with OS Giken units for E30; direct fit into the place of any open or clutch LSD unit (Viscous LSD cars (ix) need to obtain open/clutch type stub axles)
                I have built them for OS Giken Sponsored E30 S54 GTS4 cars (NASA).
                We run a 22 gal FIA rated cell with external bosch motorsports pump, foam filled and anti surge item internal - not external. its pure race only and easy to manage- since its FIA rated the rear bulkhead behind seats can be cut to have easier access to rear items/routing/etc. We needed a cell for more capacity so there was no choice. PITA to drain to store etc- If your racing purpose requires one or its advantageous to adapt the car for one due to capacity then the added weight/cost/complexity is worth it.
                If your class does not require more than standard fuel load the original tank works quite well and is less troublesome to install (its already there hopefully)
                • GT BMW E30
                  • Nov 2008
                  • 2491
                  can you guys use the factory extended fuel tank for the trunk? I have one or two in storage.
                  • 91Saleen#15
                    • Mar 2006
                    • 230
                    My interest is purely autocross. I have trouble with the stock tank leaning out on right sweepers with less than a full tank. I'm thinking of installing a 3 gallon drag racing tank.
                    Richard
                    • greg1333
                      • Nov 2004
                      • 127
                      ATL makes two different sizes of Well Cells.. they fit inplace of the spare tire.
                      Not sure what class you are running, but in some classes the size and location of a aftermarket fuel cell is restricted.
                      • djjerme
                        • 5082
                        Just use the early E30 dual pump setup (internal/external).. It's what I have in my PRO3 car, and have never had a lean out/fuel starvation issue.
                        2016 Ford Flex
                        • Wanganstyle
                          • 2828
                          use the early in tank 5psi feeder and out of tank high pressure pump setup, build a small holding box for fuel to get in and leak out slowly out of a model airplane gas tank or a milk jug (not kidding).
                          the other idea would be to run a swhirl pot mini collector gas tank in the back seat and have a high pressure pump in it; swap out the in tank pump for a low pressure unit.
                          The fuel rail could also be converted to return less using the E39 M5/ e46 M3 FPR setup+ 3.5 or whatever FPR regulator of your choice (the s54 and s62 run 5.0 bar) and a M54 rail
