The time has come for my e30 to hit the track.
  • DEV0 E30
    • Oct 2004
    • 8904
    #31
    Originally posted by Axxe
    No hood latch cable either? I thought I was the only one running around with a flat head popping my hood.
    All the cool kids use the screw driver.
    Show your boss it can do more then look pretty, have fun.
    • permit
      • Mar 2005
      • 3363
      #32
      Flat heads are too..."superior" for a car like the e30. My car had a snapped golf club in the trunk for things like opening the hood.
      • b00b00
        • Nov 2004
        • 49
        #33
        The things I can think of that haven't been mentionned are to run an extra 1/2 litre of oil (or baffle the oil pan/run an accusump) as there is some talk of m20's running into oil starvation problems when on R-comps. Also, some (my 89) have fuel feed problems on hard/sustained right handers when under a 1/2 tank. Either keep it full or IE has a solution. Special backplates and brake ducting are not a bad idea either. Torque your wheels to 85 ft/lbs every time before you go out. Do not use your handbrake for the remainder of the weekend. Have a plan for what you want to work on every time you go out.
        One of the best books I've read on driving is called "A twist of the wrist" by Keith Code. It's about motorcycles but an aweful lot applies to cars as well.
        Have fun.
        ~andre~
        www.bourandataservices.com
        • Jordan
          • 12916
          #34
          Originally posted by b00b00
          Also, some have fuel feed problems on hard/sustained right handers when under a 1/2 tank.
          I experience this alot on the street. Usually only when under 1/4tank, and when I'm (trying) to go WOT after coming out of a long corner. Its like the engine hits a revlimiter, but its just running lean. Wait 1-2 seconds and fuel pressure is back up and all is good.
          https://mtechniqueabs.com/
          • Bimmerfanatik
            • May 2004
            • 5349
            #35
            Originally posted by UNHCLL
            Anyone who thinks a novice driver will have time to take pics at a DE has clearly never been to a DE.... *cough*Scotty*cough*
            :rofl:
            Originally posted by Jordan
            Someone else will be at the track with my camera to take pictures for me :)
            That's more of what I meant LANGSTEN. :evil:
            • Dave
              E30 RAT
              • 11675
              #36
              I seem to recall he had no lever due to his custom speaker enclosures. Obviously with as anal as he seems to be about most things on his car, you wouldn't think he'd go around with a broken hood latch cable/lever.
              Back on topic - Jordan, is this a BMWCCA event you are planning ot attend or one with another group?
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • brodee
                • Jan 2004
                • 2914
                #37
                Jordan, I'm planning on getting back out to a DE after the first of the year. There are a couple of Porsche events at TWS coming up. I've run them in my M3 and they are very well handled, usually lots of the BMW guys there.
                Only thing I can add is just relax and listen to the instructor. TWS is a tough course for a DE because it's so big, lots of corners to memorize. The biggest problem I have is remembering to acknoledge the corner workers. In the green group this is a big thing with the instructors and you will never move up unless you can do it consistently.
                They will tell you not to ride with anyone else at least on the first day. Listen to this advice. I went out in a couple of cars and let the lead instructor drive mine and it messed me up for the day.
                Let me know when you're going and I'll meet you there. They also just opened Motorsports Ranch Houston and should have some events there. Would be good to run on a newly paved track. If you want to run one there you can crash at my place.
                "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                1988 M3 - Track Rat
                1989 325iC M50 Vert
                1989 325i Coupe
                1991 318is
                1995 318ti Club Sport
                2006 330i e90
                2008 Tundra Crewmax
                • b00b00
                  • Nov 2004
                  • 49
                  #38
                  On the track it will happen sooner as you will be carrying more speed through the corners and can potentially be a problem if the car is really on the limit as a sudden drop in power can upset the balance of the car. This being said, if you know where it's going to happen you can plan for it and adjust your line/speed accordingly. It's mostly just annoying to constantly have to fill up your tank as fuel mileage goes out the window when on the track.
                  -a-
                  • Dave
                    E30 RAT
                    • 11675
                    #39
                    -a-
                    I am not a good enough driver to really be concerned about the weight of the full gas tank. I filled up Saturday morning and then did it again on Sunday. Maybe after some expereince it will matter to me, but it does not for now. Fill up the tank and it should eliminate the problem.
                    Current Cars
                    2014 M235i
                    2009 R56 Cooper S
                    1998 M3
                    1997 M3
                    • terrybpp
                      • Sep 2004
                      • 340
                      #40
                      LOfuckinL. Glad to hear your finally going to put that thing to work. Although, all the wax layers that have built up over the years will put you at a severe weight disadvantage.
                      Wait till the racing fever hits you. I see 15" kosei's or equal in your future.
                      • Dave
                        E30 RAT
                        • 11675
                        #41
                        I wonder if they will fit over his brakes - doubt it.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • Jordan
                          • 12916
                          #42
                          I can count the # of times I have waxed this car on 1 hand.
                          17in is bare minimum.
                          • Skafrog
                            • 1732
                            #43
                            do you have e36 m3 brakes?
                            You can fit 16" RK's if so.
                            NASA MidSouth TT Director / GTS2 #018
                            Mods: Coastal PS Fluid, 10w40 Oil
                            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                            • e30sd
                              Fistee
                              • Jan 2004
                              • 5517
                              #44
                              16" ssr comps too, as well as 16" BBS GT2's
                              • JRKOUPE
                                • Dec 2004
                                • 3159
                                #45
                                Hey Jordan.....
                                The e 30 forums are a tight community and I feel like I know you......your reputation precedes you.....you are getting alot of love here.
                                Congrats on your decision........I bought my e 30 last year to track it full time and with much $$$$$ invested its been a blast. As a newbie to the track, you are getting great advice. Hopefully you will like your instructor as they can make a huge difference. if you dont get along it can suck..try to ask for another.
                                DO NOT GET HYPNOTIZED BY A CAR IN FRONT OF YOU. It is common and you end up making the same errors !......dont get the red mist.....meaning dont stick on some guys ass and race him.....WATCH YOUR MIRRORS. Stay away from trouble..you want to DRIVE YOUR CAR HOME!. YOU WILL LOVE IT.... and if you dont,well..... you are not a man( he he) It is an amazing time..have fun.
