racing harness recommendations?
  • peytonracer4
    • May 2011
    • 524
    i'm looking for a 4 point harness to put in my e46 for weekend use and then i want to take it out again.
    will only be using it for autocross or track days, not really wanting it for daily use at all.
    i'm looking for something cheap that is safe (obviously) and easy to install, uninstall.
    must be compatible with stock e46 seats.
    thanks
  • der affe
    Technical
    • Dec 2005
    • 8452
    What about a schroth ralley 3 or 4 set up? No need to remove them amd you could still use your stock belts.
    Just check to make sure they are sanctioned by whom ever you are racing with.
    • peytonracer4
      • May 2011
      • 524
      was hoping for something cheaper, but those might be an option.
      i'd want to remove them more than likely. i think they look dumb. haha
      • der affe
        Technical
        • Dec 2005
        • 8452
        the problem with running harness not designed to bolt into the stock locations like the schroth are they need a cage or at least a seat belt harness bar to work work correctly.
        if you just bolt your harness to the floor or the rear mounts, you can have issues with spinal compression in the event of an accident.
        i run the rallye 4 belts in my DD.
        with these you can go back to the std 3 point belt at will.
        i had these laying around from my ITB Golf as they were out of date. the retractors were going bad in my stock belts, so i just swapped them.
        they are also street legal
        • TobyB
          • 5287
          There's a reason that 5th point is there...
          ...and required by any real racing sanctioning body.
          if you can't go 5, stay 3 and do something cheap like the CG lock or the Porsche tug...
          4- points aren't racing harnesses, and scare me.
          t
          • !kid
            • 1362
            Schroth makes DOT 4 points, personally thats what I would get for your situation.
            :borg:
            • Bimmerman325i
              • 6854
              another vote for schroth or cg-lock.
              2017 Chevrolet SS, 6MT
              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
              98 M3/4/5 (stock)
              • Jaxx_
                • Dec 2009
                • 1880
                for autox i think a 4 point is fine. for anything more than that and actually risking hitting something... Don't do it if you like being able to use your legs.
                a cheap CG lock alternative is to move your seat all the way back, tug on the belt to have it lock, then move your seat to your driving position. Doesn't work for tall people, though. The alternative is to lock the belt and then unbuckle, give it a twist 360 degrees and then buckle up again, and it will be a bit tighter.
                • Deathtoll
                  • Aug 2012
                  • 1285
                  Harness
                  Scroth for sale check my sig. If u pay me what I asking ill ship for free.
                  Born and raised in oak park ill!
                  -Art
