The big one. I don't remember the numbers off the top of my head.
That's the one. We set the front to the middle position. The rear didn't have fixed positions; you had to slide the mounts back and forth. We set it so that just under 1cm was sticking out of the bracket.
With TMS J-Stock springs and dampers, 15mm H&R spacers on the front wheels only, camber set to -2deg in the front, and 225/45/50 tires on 15x7" ET25 wheels (TDR ProRace 1.2) the car was perfectly neutral and gripped like mad in the dry. The engine was a stock M20B25 and the diff was a medium-case 4.10:1 LSD from an E30 M3 rebuilt to stock specs.
You could make the car do whatever you wanted and place it wherever you wanted on the track. It rotated like a good mid-engined car: think Lotus Esprit. It seemed to pivot around the center of the car. Tricky to control in the wet, but unstoppable in the dry.
