Brake Bias Valve
  • dude8383
    • Jan 2005
    • 10387
    Brake Bias Valve
    Finally heading out to the track in September and its time to start getting the car ready.
    I'd like to install a brake bias valve in place of the factory piece beside the brake booster.
    I'm looking at several valves but not sure what to purchase. I'm more concerned with how I'm going to mate the valve to the factory lines. Whats the pitch on them?
    A few of the valves I'm considering:
    Wilwood 1/8" NPT
    OBP 3/8-24
    Tilton Metric - This looks like what I need...
    Tilton 3AN & 3/16"
    What do you fellow racers suggest?
  • dude8383
    • Jan 2005
    • 10387
    Looks like I might have answered my own question...
    So technically this should bolt up right?
    • FLG
      • Sep 2011
      • 3165
      Denis,
      Have you tried running a more aggressive rear pad to help with the bias instead? Like pfc 01's and 06's or 08's Or dtc60/70
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • petrolhead
        • 421
        It's a metric thread (M10x1), if that was what you're asking about.
        • cwbaader
          • Oct 2005
          • 30
          Note, you'll have to re hardline the rear to the bias valve...you can buy brake line with either metric or SAE fittings...and you can put one of each at each end of a line...makes things easier.
          • liquidgroove
            • Oct 2007
            • 66
            I had wilwood one with M10 threads. Don't think Wilwood sell it anymore.
            anyway, i just took out the factory bias valve and put the adjustable unit down there. No need to make new lines. I can reach it from top to make adjustment.
            Ideally adjuster should be somewhere driver can access at all time to make adjustable easily.
            • dude8383
              • Jan 2005
              • 10387
              Originally posted by FLG
              Denis,
              Yep. I've experimented with all sorts of stuff. Its time to step it up a knotch to dial this fucker in so I can finally get more than a days worth outta my pads!!
              YES! Thank you man.
              Perfect. I would love to bring it into the cabin but I think leaving it in the factory location will be fine.
              Thanks guys. Going to order this guy soon.
              • SkiFree
                • Jun 2011
                • 2766
                I typically don't like just posting links (especially for someone I work for). But.....
                Threaded for BMW metric 10mm x 1.0mm lines.
                ADAMS Autosport
                • dude8383
                  • Jan 2005
                  • 10387
                  http://www.iemotorsport.com/bmw/E30-brakes/wwvalve.html
                  Woah. That's about half the cost! Any significant differences between the two?
                  • Jean
                    • 18228
                    Keep us posted with results with whatever valve you end up getting.
                    • SkiFree
                      • Jun 2011
                      • 2766
                      Well.... no easily discernible differences that I can see. Most our shop race cars use it along with who knows how many 2002/E30 track cars out there. Probably sold a couple hundred over the last several years.
                      ADAMS Autosport
                      • TobyB
                        • 5287
                        I used it in the 2002 before I did a bias bar... worked fine.
                        Need to put it into the E30, since it really doesn't like braking going down hills over bumps...
                        t
                        • dude8383
                          • Jan 2005
                          • 10387
                          Will do! Waiting till next month before I start making the big purchases.
                          Gotcha. Thats what I needed to know! I'll be in touch at the end of the month :)
                          t
                          Awesome, thanks for your input!
