time attack setups
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Team Dynamics are a good cheap track wheel for E30's.
    Do you know what class you are going to run, could you post up the rules.
    • kman_e30
      • May 2007
      • 573
      i need to get 15s my wheels are 16s
      i want to run in the street class
      84 318i drift car
      04 mk4 gti 1.8t
      96 e320
      63 plymouth valiant
      • 10Toes
        • Jan 2008
        • 61222
        After looking over the rules for street class, I don't see anyway to make an E30 competitive in that class even if you spent $25k+ Doing all the work yourself.
        • blasphemy101
          • Apr 2012
          • 170
          What specifically makes the e30 so uncompetitive?
          The Great Big M20 Timing Belt DIY
          Some good information I've found online (no affiliation):
          Turbo Tech (Garrett)
          Four-cycle information and cam properties for beginners (ISKY Racing Cams)
          • 10Toes
            • Jan 2008
            • 61222
            It's 30 years old
            • QUKBMER
              • 8178
              I am running billy sports f/r .... ie 3 race springs f/r ....ei rear shock mounts/stocks up front.....ie 25mm f / 22mm r swaybars ... poly everything f & r .... ie front strut bar ..... 4 point chromemoly cage by concept II motorsports welded in / rear bars running down to rear shock towers with cross strut bar welded in ... stock brakes w/ate brake pads f/r .... ate super blue fluid..... ltw d-force wheels 15x7 .... nitto nto1's 205/50/15 or hartge wheels 16x7.5 hankook rs3 225/50/16 tires ....stock 2.5 m20 (i have a new (no regrind)272 cam to install w/hd rocker arms to install along w/shorty headers)... mark d chip w/17 lb injectors on 91 otc gas .... 4:10 lsd w/z3 m diff cover w/redline fluid... so far.8-) I can take you out at adams for a ride so you can see how it handles.
              • robgoesvroom
                • 821
                Hey kman when are you going to another trackday? You should message me! I'd love to go on track with more E30 guys!!
                • Massimo
                  • Jan 2008
                  • 3207
                  Buy this book and read this book, it is a bit old but the theory still is the same and will open your eyes to making your car handle.
                  • QUKBMER
                    • 8178
                    Thats a very good book ^^^,bought that years ago .
                    • Wanganstyle
                      • 2828
                      Missing......New heavy duty or billet rocker arms :)
                      the one weak point of M20 - I Have a broken one as a trophy from 3 races ago
                      • QUKBMER
                        • 8178
                        Its in there right after the billet cam (w/hd rocker arms).:up:
                        • Wanganstyle
                          • 2828
                          cool just wanted to make sure.
                          I was in 7th position out of 190 teams 4 hours into the race......... and then.....broken rocker arm on #1.
                          GRRRRRRRR!!!!!!
                          • Eric
                            • 5139
                            It's 30 years old
                            • kman_e30
                              • May 2007
                              • 573
                              im gonna deff take you up on that offer, text me next you go to the track.
                              what about running 14's, with a 195 60 tire?
                              84 318i drift car
                              04 mk4 gti 1.8t
                              96 e320
                              63 plymouth valiant
                              • Wh33lhop
                                • 11705
                                Not much cheaper tire cost wise, less tire choice, and slow. Just do 15x8-9s. Cheap tires, light and good grip.
                                paint sucks
