Good to know there's another cheap option out there for 15x8's. They have them in et20 too. Would just need to run rubcentric rings, no biggy.
Ideal tire for 16x8.5 on an e30
And good-win is about to release another option from Konig and another company that should work as well.
9" get's more difficult for E30s.....wait do the TRMs fit? I know they are heavy, but if buy a light cheap wheel and then have to use monster adapters that would probably weigh even more.
Or you can drop $3000 and have Jongbloed/Keiser or any number of other companies to build you 3piece wheels to your spec.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Good to know. I'll keep my eyes open.
I don't know anything about trm's 9" wheels.
That's way too much money to spend on wheels alone especially since i just autocross for fun.Comment
I run 225/45/16 specs on 16x8.5 et27 at the track and love the setup. I also have a set of 16x8.25 et0 running 245/35/16 rear and 215/40/16 front for the street and they are great for cruising, but rub at full squat in the rear.
2012 MCSCC/NSSCC CP class champ
HSAX InstructorComment
^Depending on the weight of your wheel, I wouldn't be surprised if you couldn't pull 5lbs per corner of rotating weight by going to 225/45/15Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
My track wheels are Kosie K1, pretty light. My street wheels are XXR 527 which are heavier than the K1 but still pretty light. I can't fit a 15" wheel over my bbk.
Could you post a picture of this?
I use my TRM C1s over the Massive Sport Kit. A slight shave of the caliper and it fits the barrel. The spokes have lots of clearance
S50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
There are some Konigs that fit the bill. I'm running the Flatout's now, 15x8 Et25 with 205/50 R888s. Check out www.good-win-racing.com
It easily fits this 11" Dynapro setup.
Will the Flatouts fit the UUC BBK? Also do you think it would be possible to fit 225/45/15 on 15x9's, maybe 6uls' with spacers? What would the et have to be? High teens after spacers?sigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/Comment
Why? Heavier, more expensive tires, etc.
How big are your brakes? As you can see below, you can squeeze a 300mm rotor under the right 15" wheel. Ducting and proper pads and you'll never need any more than that on an E30.
No, I don't care to go digging up old threads on other forums. I'm glad you like them, I just wouldn't spend my money on them, but mostly because of weight.
I have absolutely no idea. Does UUC have a fitment template for it's kit? If so, you could possibly contact the vendor and say, "If you will check this template on your wheels, and they fit, I will buy a set."
As for 225/45 on a 9", refer to post #26.
As for fitting 6ULs with spacers, do some research. About what ET is needed to fit a 15x9 on an E30.Last edited by z31maniac; 11-27-2013, 10:19 AM.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Its just 280mm RX7 kit. The K1 I run is tight on the caliper, but I know there are 'some' 15" wheels that will fit. I have other reasons for 16", and for a stockish e30 I agree a 15" will perform as well as a 16" if it fits but IMO it won't look as good. You're also right about 300mm brakes being more than enough, all personal preference at some point you know? The weight between my 16" and you're 15" is nominal, and I prefer the former.
14.5 lbs, inexpensive, and good brake clearance. I have never heard of abysmal quality control that you mentioned. I'm only trying to educate myself on what I have experienced as a very good track wheel.
Do you recall what forum had the quality control discussion?
S50'd
Most definitely is personal preference.Its just 280mm RX7 kit. The K1 I run is tight on the caliper, but I know there are 'some' 15" wheels that will fit. I have other reasons for 16", and for a stockish e30 I agree a 15" will perform as well as a 16" if it fits but IMO it won't look as good. You're also right about 300mm brakes being more than enough, all personal preference at some point you know? The weight between my 16" and you're 15" is nominal, and I prefer the former.
My preference is all performance, couldn't give a damn about form.
www.gutenparts.com
Almost 2.5 lbs heavier than the 15x8s I run, and your wheels are still heavier than a 15x9.
It's been on some of the different Miata forums.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
