Ok guys I have a few questions about wiring my OBDII S52 drift car.
My goal is to:
Delete the fuze box inside of the engine bay.
Delete ABS.
Delete Power Steering.
Delete Brake Booster.
Delete Gauge Cluster.
Pretty much delete anything that is not really needed.
I will be running the bare minimum and wiring in my own gauges
-Tach.
-Water temp.
-Oil Pressure.
-Voltage.
Is this possible with one of these?
I would like to wire the engine harness straight into a fuze relay board, rather then sending my harness out to get modified to connect to the stock fuze box.
ARC Flat Touch Switch Panels 8000R
I will be assigning each switch as follows
-Iginition
-Starter
-Headlights
-Aux Fan
-Windshield wipers
Cant think of anything else at the moment. Some input on what should go on the switches from someone who has wired something similar would be awesome.
The main goal is to delete the fuze box under the hood and relocate an aftermarket setup inside of the vehicle while keeping the bare minimums for the car to run.
I love criticism, so don't hold back. got to learn from experiences.
thanks gents!
My goal is to:
Delete ABS.
-Tach.
-Water temp.
-Oil Pressure.
-Voltage.
-Iginition
-Starter
-Headlights
-Aux Fan
-Windshield wipers
thanks gents!
