what rotors on Massive street kit?
  • JRKOUPE
    • Dec 2004
    • 3159
    What rotors are yall using on the street kit?...1 pc....
    I just read how brembo and even ate, may have design flaws leading to issues w/ track use?
    .....hmmmm...
    possible failure where hat is attached to outer ring?..
    my RB's cracked after 2 yrs( not at hub area)....and RB no longer even makes them..1 or 2 pc.....
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Stop tech is popular
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • JRKOUPE
      • Dec 2004
      • 3159
      have you tracked w/ them?....
      it seems that stop tech is centric..or vice versa...for this app......
      • kronus
        • Apr 2008
        • 13032
        we've put probably 40 hours of endurance racing on stock-replacement duralast rotors and they didn't do that.
        cars beep boop
        • JRKOUPE
          • Dec 2004
          • 3159
          on the massive street kit?......hmm..
          (my research reveals brembo and perhaps even ate have cut outs in the hub./welded area...and meyle for instance does not..)
          stop tech told me the rotor is a 1 pc cast....
          • kronus
            • Apr 2008
            • 13032
            not, not on the massive kit. I'm just saying I have no idea how you guys are doing this to rotors.
            cars beep boop
            • JRKOUPE
              • Dec 2004
              • 3159
              ok.....nobody is saying we guys are doing this..lol.....that pic was just a look see on what has happened to some w/ that rotor.( that is not a massive bmw set up either..it just represents a corrado rotor)
              Ive just read how there may be a design flaw on the brembo , and perhaps ate rotors for the Corrado 1 pc rotor set up.........
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Two totally different cars. I got stock brembo rotors and love them. Also got stock bav auto sport rotors and those aren't bad either.
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  thatoneeuroe30:
                  "2 totally different cars...."......you lost me?
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Agree, that pic in the lead is nuts, maybe it has to do with pad choice?
                    Even so, we have had no issues with Brembo blanks in Chump racing. Do they develop small cracks, sure, does that make them useless, hell no. Of course we change them after each event, so don't expect more than 24 hours from a set of rotors, and even that is asking a lot. Granted this is with M42 power, and of course more HP may equal more HP stopping from the brakes.
                    Don't over think it, and if you really think that cracking is going to be an issue you need to concentrate on brake cooling/pad choice and probably not so much on metallurgy which is something mfrs will probably not disclose.
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      hey fellas.....all responses are appreciated but u may be missing the point.
                      There have been a few issues w/ brembo and ate re rotors cracking/failing on CORRADO replacement rotors....
                      its not related to brembo or ate on any other applications.
                      I ran both brands on oe e 30 set ups for years and loved them!...
                      Im asking re corrado application which in this scenario is used on a bbk
                      back to normal programming.
                      • dude8383
                        • Jan 2005
                        • 10387
                        hey, why not switch to a two piece? i have massive's cnc'd hats and run wilwood rings. won't have any splitting issues!
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          Originally posted by JRKOUPE
                          thatoneeuroe30:
                          The vw carrado and bmw e30 are two totally different cars.
                          • z31maniac
                            • 17566
                            Also duct the brakes to keep the heat down.
                            www.gutenparts.com
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              D....
                              I like the 2 pc idea..but this kit w/ its 12mm pad, I just think its not worth the costs...I rather just put more cash into the massive sport kit.
