Camber plates or sway bars?
  • jayuuey
    • 414
    I'm in the process of refreshing my e30 for hpde. After engine maintenance, brakes, springs and shocks, what's next? I'm thinking either sways or camber plates. What's the best bang for the buck?
  • E30_Pare
    • 7801
    Cabrio front sway from the junkyard and camber plates.
    DREWLIENTE
    1$ PShops PM me
    • E30NJ
      • Aug 2013
      • 921
      Start with sway bars. Cabrio sway bars are a good upgrade becuase they are beefier. Just be careful because some cabrios have the same sway bars out of a regular E30s. Front should be a diameter or 21mm and the rear should be 12 mm. I've heard great things about Ireland Engineering Sway Bars but they are a bit pricey. Bav Auto makes some good ones too. Let us know what you decide!
      • acolella76
        • 2950
        Well what spring rates are you running? Sway bars should be matched to your springs, and are really dependent on driver preference. For instance I don't run a rear bar on the track but I'll reconnect it for an autocross so I can get the car to rotate easier.
        -Alex
        • Jaxx_
          • Dec 2009
          • 1880
          remember, bigger front = more understeer. bigger rear bar = more oversteer.
          • GillesBigCowboy
            • 507
            Without camber plates, I would always get excessive outside tire wear at track.
            87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
            • lcoleman
              • Jan 2009
              • 331
              I think a proper amount (3+ degrees) of front camber will make a bigger difference than sways unless you have totally wimpy spring rates.
              Front sway on these cars is more important than rear. Not sure why, just my experience. Guessing it has to do with suspension design. It seems to help with understeer more than it hurts. Both bars is obviously best, along with proper adjustable endlinks.
              • SkiFree
                • Jun 2011
                • 2766
                It's because the E30 uses a really short spring in the rear and there aren't any standard or 2.5" springs that are short and soft enough when we're talking performance/race use. As a result rear spring rates are artificially high (given that's what available). This is why many tinkering racers try different combos and end up running adjusters that use a 2.25" spring (that is available in some of the shorter, softer rates).
                ADAMS Autosport
                • Emre
                  • Sep 2007
                  • 1228
                  Except, of course, on cars with McPherson front struts. In which case the exact opposite is true (up to a point).
                  1987 Mercedes 190E 2.3-16: Vintage Racer
                  2010 BMW (E90) 335xi sedan: Grocery Getter
                  • MX339
                    • Feb 2012
                    • 123
                    Interesting, I always thought the high rear spring rates on 02's/E30's were due to the inboard positioning of the spring perch which changed the wheel rate, necessitating a higher spring rate. So I take it that means a softer rear spring than something like what H&R Races are supplied with will actually calm the rear end down?
                    75' M42 Powered 2002
                    AW 318is
                    • TobyB
                      • 5271
                      I have found this to be true. The E30 doesn't have enough front camber for radial tires
                      when tracked. Even as a relatively under- driven 'a few play laps' car.
                      As to rear rates, yes, the rear rate is high because the spring rate's something like
                      .68 or so of the wheel rate, and that math is squared. So for a car with
                      #600 in front and rear, the front wheel rate might be #550, but the rear would be
                      more like #300.
                      And sway bars will depend in great deal on what springs you're running...
                      And as well, I found a 5" 2.25" spring with fixed spacers was a lot better than coil bind!
                      Now if I could just find that pot of gold at the end of that pesky rainbow...
                      t
                      • jayuuey
                        • 414
                        I found a local deal for KMAC Stage 2 camber/caster plates. After some further research it seems KMACs are less desirable than GC, UUC, etc. Anyone have experience with them on here?
                        My current suspension setup consists of HR Race/Billy Sports, 205/50/15 w/TRM 15x8s, Condor offset fcabs. I'll primarily do hpde, drive to and from the track, no dd.
                        Car is an 87 325e 11/86 build (327i in the next week or two).
                        Thanks for the input thus far.
                        • lcoleman
                          • Jan 2009
                          • 331
                          For a car like that I'd rather have plates with a spherical bearing and full adjustability (and I do!). You really need to be pushing the spring perch to where it touches/almost touches the stock strut towers for the best results. For me, the resulted in about -3.1* per side.
                          • jayuuey
                            • 414
                            Which camber plates are you running?
                            • lcoleman
                              • Jan 2009
                              • 331
                              I have Vorschlags and love them. I've also worked with GC plates, and they're quality as well. I'd give a slight edge to Vorschlag, but more $$.
