Suspension design types on different ethusiant cars
  • rwh11385
    lance_entities
    • 18403
    with all the hating on e30's ancient design and talking about auto-x recently, been wanting to findout what all ethusiant cars use for suspension setups
    here's a start:
    84-91 E30: Macpherson strut front / Semi-trailing arm rear
    92+ E36: Macpherson strut front / Multilink rear
    Mini Cooper (BMW): Macpherson strut front / Multilink rear
    Evo 8: MacPherson strut front / Multilink rear
    years? FC RX-7: Macpherson strut front / Semi-trailing arm rear
    (w/ hubs that alter toe?? DTSS?)
    93+ FD RX-7: Double wishbone front / Multilink rear
    RX-8: Double wishbone front / Multilink rear
    993 (- current) Porsches adopted a multi-link rear suspension which was originally developed on the 928
    I believe all MkI to MkIV Golfs, Jettas, GTis were macpherson strut front and torsion beam rear. Torsion beam is a semi-independent trailing arm set up.
    I believe all 944s (924, 944, 951, 968 ) were macpherson strut front and semi-trailing arm rear.
    Hondas before the 2000s: all double-wishbone all around for the most part?
    2004 Sentras - All SE-Rs feature front independent MacPherson struts and Nissan’s patented rear Multi-Link Beam™design.
    99+ G20 (P11) "The G20's combination of a multi-link front suspension with a multi-link beam beam rear suspension seems like the Harvard-Phd-meets-prison-work-release mismatch of the century" http://www.se-r.net/about/g20/scc/oct98/tb.html
    Miata: General: Front engined - Rear wheel drive, Double overhead Cam, All round independent wishbone suspension, weight generally less than or around 1000Kg, power is 116-140 bhp, 0-100Kph in 7.9 - 8.6 Secs. Disc brakes all round.
  • Rob
    • 8166
    admitting that suspension technology has passed E30s is not hating fwiw, but I digress...
    I'd like to see specifics on the MKII and MKIII vee-dubs, as well as other e30 competition (NA 944, older MR2, Celicas, etc)
    BEERTECH
    • rwh11385
      lance_entities
      • 18403
      a lot of old 911s were semi-trailing arm-ed? right?
      what are they running on 993s?
      i can slowly search and find more during work. but maybe someone will take it upon themselves or know of more data already
      • Rob
        • 8166
        all the air cooled cars are the same AFAIK, except the 964 (1991ish+?) started using coiled springs instead of torsion bars. Same basic design though.
        I have no clue what the new pooshies are doing to fight improper balance, but they seem to be doing it well
        BEERTECH
        • BimmerToad
          • Sep 2004
          • 1537
          993 (- current) Porsches adopted a multi-link rear suspension which was originally developed on the 928, called the weissach axle (IIRC). It basically allows for more incompetent driver to lift mid corner without worry :up:
          I'm amazed so many sports cars are still using a MacPherson front end. Guess it doesn't matter once you get a decent set of plates in and dial in the camber
          Are Miatas really double wishbone front and rear?
          San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
          • rwh11385
            lance_entities
            • 18403
            Everything about the car had a delightfully light touch. Instead of smothering the pavement under huge rubber, it relied on careful tuning of the double wishbone (front and rear) suspension to get the most out of modest P185/60HR14 tires. Power steering was an option, but the standard manual rack-and-pinion setup reacted instinctively to steering inputs and reported back even subtle details about what was going on with the tires. The four-wheel disc brakes weren't very big, but they didn't need to be on this car.
            http://www.edmunds.com/insideline/do...rticleId=96932
            • redcarbon
              • Apr 2005
              • 213
              Yes, all hondas up to the 2000s or so had double wishbone all around. I believe all MkI to MkIV Golfs, Jettas, GTis were macpherson strut front and torsion beam rear. Torsion beam is a semi-independent trailing arm set up.
              I believe all 944s (924, 944, 951, 968) were macpherson strut front and semi-trailing arm rear.
              I think the e30 suspension works great, plenty for us street users. My e30 has a fully independent suspension while my 11 year newer VW has a semi-independent rear suspension. Even the VW macpherson strut design pales in comparison to the elegant e30 design.
              318is -gone-
              • BimmerToad
                • Sep 2004
                • 1537
                More I learn about the Miata, more I want one! Too bad they never produced a coupe.
                • Jarvis
                  • 2132
                  Custom rollcage + add-on hard top... miata coupe.
                  • rwh11385
                    lance_entities
                    • 18403
                    Join the club....
                    I am just checking out for a little more info, and affordable ones, i think a 94 would be one to get.
                    My local pal has a turbo one which is siiiiiiick. (daily driver). Here is one from the shop he works at. http://video.google.com/videoplay?do...69898977036457
                    oh yeah, as if having at friend at a Miata wasn't enough, Mazda will give you 50% off your OEM parts if you prove you attend 3+ auto-xes a year...!
                    • rwh11385
                      lance_entities
                      • 18403
                      there are those who bash e30 suspensions (bimmerforums e36+ guys), but as shown in several ways, it can be made to work or driven regardless of
                      oh well, better to learn on the harder to handle suspension than the easy-to-go-fast more advanced one. and it works well enough for the street.
                      screensaver car turbo desktop import 0-60 download free, 2002-2005 Volkswagen GTI 1.8T / VW Golf 1.8T
                      2006 GTI (and I assume other of that family) have multilink independent suspensions now, finally. lawlz.
                      • rwh11385
                        lance_entities
                        • 18403
                        need to find...
                        Ford Focus
                        Supras
                        240sx
                        camaro
                        mustangs
                        s2000
                        lotus elise
                        srt4
                        wrx
                        old neons
                        older celicas
                        mr2
                        viper
                        crx?
                        • rwh11385
                          lance_entities
                          • 18403
                          2002 Honda Civic Si ... There are a MacPherson strut front suspension and a double-wishbone rear suspension
                          The 1988 CRX debuted alongside the fourth-generation Civic and was therefore among the first cars to use Honda's ingenious new four-wheel, double-wishbone suspension system.
                          All Focus models are front-wheel drive cars with a fully-independent suspension with MacPherson struts in front and a multilink design Ford calls ``Control Blade'' in the rear.
                          Introduced in 1979 as a model of the Celica, the Supra has been related to the critically acclaimed 2000GT sports car, whose 2.6 liter straight-six engine it used; at first it had a solid-axle rear suspension, and the twelve-valve engine only produced 110 hp, with fuel injection. The Supra was longer than the Celica liftback by a good five inches. Four wheel disc brakes were standard, as was a five-speed manual transmission; a four-speed automatic, unusual in those three-speed times, was optional. The MacPherson strut suspension included a sway bar, and the rear suspension had a stabilizer and sway bar.
                          The second generation began in 1982, with the engine given twin overhead cams to bump horsepower to 145 hp (it bumped to 150 in 1983, 160 in 1984, and 161 by 1986), as well as an independent rear suspension to keep all four tires on even bumpy roads.
                          The 1982 Celicas kept the 2.4 liter (144 cubic inch) engine that pushed out 96 horsepower with a two-barrel carburetor or a rather better 105 horsepower with electronic fuel injection (that would eventually rise to 116 hp by 1985); Australian models used a lower power 21C engine.
                          While the Supra was now a model of its own, rather than a Celica model, the Celica GT-S used the Supra’s independent rear suspension
                          2000+ Celicas: Independent MacPherson strut front suspension / Rear suspension Double wishbone
                          The 1998 240SX is relatively unchanged from its predecessor and Nissan will continue to offer three trim levels: Base, SE and LE. All 240SX models are equipped with a four wheel independent suspension with MacPherson struts in the front and a front stabilizer bar. The rear suspension includes a multi-link design with coil springs. (same with 91 era s13s as well)
                          MKII MR2 - macpherson strut F/R.. same as Boxster?
                          Subaru new STI - inverted struts F/R???!?
                          The 2002 WRX’s suspension system has been revised for greater stability, response, and reduced noise and vibration. The front suspension is derived from a MacPherson strut design that features L-shaped lower control arms that attach to the chassis through vibration damping liquid-filled bushings. The improved geometry of the WRX and RS models (which arrive on U.S. shores with a 20mm wider track) provide added stability while quickening steering response. The WRX sedans push the strut position and wheel hub assemblies outward 10 mm to reduce ground contact angles and reduce body roll. The dual link rear strut suspension uses a trailing link and two vertical links per side in conjunction with a stabilizer bar. The rear suspension crossmember is lighter and stronger than those on the previous generation Imprezas.
                          • rwh11385
                            lance_entities
                            • 18403
                            BALLER ASS LINK: http://www.sandsmuseum.com/cars/elis...getagrip2.html
                            and yes, i'm wasting time at work..
                            • BimmerToad
                              • Sep 2004
                              • 1537
                              www.mulsannescorner.com/ <-- great waste of time
                              double wishbones w/ pushrod and rockers >>> all
                              Hardtop Miata would be a load of fun .... I'd need to mount a fixed shell in it though, to get some headroom
