What are the symptoms of a won clutch guide tube?
  • Lof8
    • Oct 2006
    • 2827
    *worn clutch guide tube
    I've been tracking my s50 e30 for about 5 years (with G260 trans). The first 4 were with a Sachs m20 clutch. Eventually I started getting some slippage and figured the clutch had enough. I ordered a Spec stage 2 to put in. With the trans out, the Sachs clutch didn't look awful. The guide tube had some slight scoring, but nothing too concerning, so I put it back in.
    Now, after two track days with the Spec clutch, I'm experiencing the same slippage. I'm thinking the guide tube may be the culprit, but I don't have enough experience to be sure. I'm not looking forward to pulling the trans again and certainly dont want to do it a third time if I don't get it right on this try.
    Please give me your thoughts. thanks
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • Lof8
    • Oct 2006
    • 2827
    When I search "guide tube" in the title, I get 2 results. It doesn't seem like this is a common issue. This sucks - pulling the trans is wack.
    S50'd
    • jalopi
      • 2370
      the hell is a guide tube? i'm assuming you're talking about the quill? i don't see why the quill or "guide tube" would cause the clutch to slip - all it does is hold the throw out bearing in place while it rotates and/or moves forward and back. even IF the quill was scoured super bad and the TOB had issues with returning, the force of the pressure plate fingers would force it back (doubtful though, the quill would have to be SUPER fucked up for this to be the case)
      my guess is you've got a clutch adjustment issue or something. maybe the clutch wasn't broken in properly? who knows. but i'd stop thinking about the quill, it's most likely something else
      • Wh33lhop
        • 11705
        I'd suggest a close inspection of your clutch hydraulics. Something isn't letting the clutch fully engage.
        paint sucks
        • pandaboo911
          • 2070
          My "guide tube" was beat to hell and hasn't given me any problems. I didn't grease it either. Your slippage is coming from elsewhere. You should baby it the first 500 miles to break it in.
          • Hooffenstein HD
            • Nov 2012
            • 1388
            What's the slipping like? Just as you let off clutch, only when you put all the power down, or just general clutch slip all the time?
            • Lof8
              • Oct 2006
              • 2827
              The slippage happens late in the session, when temps are high. It happens in 3rd and 4th gear, with the gas pedal to the floor. release clutch, apply throttle, and rpms rise faster than the car accelerates.
              I did break it in for close to 1000 miles before bringing it on track. I also replaced the rubber clutch line with a new ss one at the time of the recent clutch change.
              So it seems the guide tube/quill experience is that being in flawless condition is not a necessity. Maybe the Spec clutch just isn't up to the task. But the Sachs one I took out wasn't in horrible shape. I'm not sure what direction to look.
              S50'd
              • jalopi
                • 2370
                sounds like that's your issue - poop clutch disc. if it was a hydraulic/adjustment/other mechanical issue i think it'd be showing up even when cold
                i'd personally get another sachs since you said it worked for you for almost five years. the disc itself may have looked just fine but maybe the disc was starting to glaze over? maybe that's why it's slipping? regardless, the sachs was reliable for years and the spec has proven itself to be junk.
                also make sure to have the flywheel ground again this time too, never know if the excess slipping made for a poor surface again
                • Wh33lhop
                  • 11705
                  The Sachs clutch disk may not look too worn, but keep in mind you have another 90hp or so going through it (torque matters more but you get the idea). So, it's likely fine behind an m20, but it will fall short behind an s50. Hydraulic issues could be exacerbating the issue, or spec clutches could just be garbage--I don't know much about aftermarket clutches.
                  paint sucks
                  • z31maniac
                    • 17566
                    I still don't know what a "clutch guide tube" is?
                    Input shaft for the transmission?
                    Clutch fork?
                    www.gutenparts.com
                    • FredK
                      • 14763
                      • ajhostetter
                        • Apr 2013
                        • 1218
                        Originally posted by FredK
                        23111224845
                        No no, it's 8675309
                        2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
                        • nrubenstein
                          • 3148
                          Run an E36 M3 clutch/flywheel assembly.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • TobyB
                            • 5298
                            To answer the original question, a binding/worn/sticky guide tube gives you a stiff pedal that doesn't have much 'kick' back to retract. It feels exactly like what it is- extra friction
                            in the clutch system.
                            Fords do it. I've only had one E21 do it, and that was water getting down in there
                            through the timing light hole.
                            If your clutch travel feels good, I'd doubt it's a tube problem.
                            (the tube is the sleeve that the clutch throwout bearing rides on. Aircooled VW's didn't have them originally)
                            t
                            • Artful Dodger
                              • May 2008
                              • 156
                              I would check the relationship of the clutch disc, pressure plate and flywheel. Maybe your flywheel is a bit worn down and you are not getting full contact pressure from the pressure plate.
