Good ways to reduce the unsprung weight
  • Jb325is
    • 2137
    Originally posted by Wh33lhop
    Yeah from what I understand about your car you're already at the point of diminishing returns--it gets a lot pricier and/or less street friendly from here. If this is your only car, I'd spend the money on seat time.
    Yep. If anything, some good coilovers for adjustability. 2450 lb e30 with 200hp and good shocks should be a rocket on the track.
    - '88 m54 coupe
    <3
    • 2mAn
      SeƱior Mod
      • 20871
      seat time... good idea. why didnt I think of that (not being sarcastic)
      Originally posted by Jb325is
      Yep. If anything, some good coilovers for adjustability. 2450 lb e30 with 225whp and good shocks should be a rocket on the track.
      ftfy. I think I will focus on making the idiot behind the wheel better and eventually get coilovers.
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • Wh33lhop
        • 11705
        What suspension are you running?
        paint sucks
        • 2mAn
          SeƱior Mod
          • 20871
          Bilsteins & IE3 Race. Treehouse racings CABs. iX & Vert sways. I think Bilsteins will need to be rebuilt soon or maybe just buy Koni's.... or GC Coils
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • Eric
            • 5142
            http://www.akgmotorsport.com/catalog/catalog.php
            FK3036
            • agent
              Vice Grand Pubaa
              • 7960
              Originally posted by jalopi
              it's sprung, but ditch the current battery for a miata battery
              honestly going any further than that is just wasting your time man. unless you go extreme with your reductions you might net you a loss of 25-50lbs or so. you might notice the difference, but that's only a reduction of roughly 2% (that's with a generous weight guesstimate of 2500lbs)
              At the track this past weekend I had two instructors tell me (in unrelated conversations) that 8 pounds is the equivalent of 1 HP. So trunk tar removal alone means effectively gaining 6 HP.
              Originally posted by kronus
              • jalopi
                • 2370
                6hp... lol
                but in all seriousness that's an interesting factoid (if it's true)
                after crunching some numbers it makes sense though, my bike, which runs roughly the same 1/4 mile times as a Z06 vette, when compensating for the weight using the 8:1 formula gets you almost exactly the same amount of power
                • e30_302
                  • Sep 2013
                  • 453
                  Reducing unsprung weight does not always equal faster laps. Case in point: I went from a 15x6 wheel to 17x9's, combined extra weight of the wheel/tire was probably 20# per corner. Lap times decreased dramatically due to the extra grip.
                  • dsm2002
                    • 193
                    6hp... lol
                    I know race engine builder who's motto is: "I never met a hp I didn't like". Therefore 6 likes!
                    • Hooffenstein HD
                      • Nov 2012
                      • 1388
                      So you needed more grip. Retain the same amount of grip while reducing unsprung weight and post results.
                      • Eric
                        • 5142
                        I wonder where the crossover point is between spring and u spring weight on the rear subframe.
                        you could try a small case diff, I think that is about 30lbs lighter. 16x8 enkei rpf1's are sub 15lbs I think.
                        • Axxe
                          • Aug 2004
                          • 3355
                          Diff is sprung. Not worth going to a glass diff for weight in quite possibly the best spot to have weight in an E30.
                          Keep it slideways!!
                          • e30_302
                            • Sep 2013
                            • 453
                            Not the point. Of course if it was lighter, it would be better. But that would require very expensive new wheels, which I am not interested in buying.
                            • Wh33lhop
                              • 11705
                              6hp... lol
                              That ratio will depend entirely on the power to weight ratio of the vehicle in question. You can check it pretty easily:
                              Let's apply it to an 325i with boltons weighing 2700lbs and making 180hp
                              -Baseline 2700#, 180hp, 2700/180 = 15.00lbs per hp
                              -Remove 8#: 2692#, 180hp; 2692/180 = 14.96lbs per hp, .04 difference from baseline
                              -Add 1hp: 2700#, 181hp; 2700/181 = 14.92lbs per hp, .08 difference from baseline
                              So in the case of a bolt-on E30, 8lbs makes about 1/2 the difference 1hp does. So roughly 16lbs is worth 1hp.
                              If we use a track prepped swapped E30, say 2400lbs and 270hp
                              -Baseline 2400/270 = 8.889lbs per hp
                              -Remove 8# = 8.859lbs per hp
                              -Add 1hp = 8.856lbs per hp
                              So in this case it's roughly correct. In fact, the 8lbs/1hp rule will be spot-on when your power to weight is 8lbs per hp. Kind of makes sense, huh? :)
                              paint sucks
                              • Wh33lhop
                                • 11705
                                The effect the diff has will depend on how it's mounted. With stock bushings it'll be semi-sprung weight, though it's not unsprung in the way that suspension is; with stiff bushings it'll be fully sprung. Either way I'd advise against removing weight from the rear at the expense of robustness.
                                paint sucks
